[Ovmsdev] Support for Kia e-Niro
Fri Mar 1 22:36:33 HKT 2019
Geir,
that's great news!
I'll integrate the images for the Android App.
The Hyundai Kona reportedly has the same drive train as the e-Niro -- will the e-Niro support also cover the Kona?
Am 01.03.19 um 14:26 schrieb Geir Øyvind Vælidalo:
> Hi,
> I’m working on support for the Kia e-Niro, so as a part of that I’ve added images for the e-Niro in the App.
> Mark, it would be great if you could merge my pull request to the iOS-app 🙂
> Also, maybe someone could add the images to the Android app too?
> A first version for the OVMS module will be coming soon. I hope 😜
> There was an issue with polling using Extended 16-bit PIDS. There were no support for flow control and multiple response frames, so I’ve added that, similar
> to 8-bit PIDS. I see that it is used in ThinkCity and Volt/Ampera. Did it work there without flow control?
> Best regards,
> Geir
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20190301/32186f47/attachment.htm>
