[Ovmsdev] Support for Kia e-Niro
Geir Øyvind Vælidalo
geir at validalo.net
Fri Mar 1 21:26:01 HKT 2019
Hi,
I’m working on support for the Kia e-Niro, so as a part of that I’ve added images for the e-Niro in the App.
Mark, it would be great if you could merge my pull request to the iOS-app 🙂
Also, maybe someone could add the images to the Android app too?
A first version for the OVMS module will be coming soon. I hope 😜
There was an issue with polling using Extended 16-bit PIDS. There were no support for flow control and multiple response frames, so I’ve added that, similar to 8-bit PIDS. I see that it is used in ThinkCity and Volt/Ampera. Did it work there without flow control?
Best regards,
Geir
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20190301/a9cc64ab/attachment.html>
