[Ovmsdev] iOS-App
Mon Jun 24 16:55:00 HKT 2019
OK, let’s see how it goes.
P.S. If it helps, your server replied "250 2.0.0 Ok: queued as 27EEEA160D”.
> On 24 Jun 2019, at 4:43 PM, Martin Hofgesang <martin.hofgesang at gmx.de> wrote:
> Hi Mark,
> many thanks, I found the setting and it worked!
> From a customer point of view I would agree with the automatic switch and a merge of Smart ED and EQ, but from a developers point of view I would like to first start with a seperate module, cause the can ids have nothing and really nothing in common [1] and to merge it would mean we always have to test both the ED and EQ part of the module when making changes and pull it into the live system to get sure the EQ part defeats not the ED part and vice versa.
> In our current state, where there is much work in the ED and EQ part it would make the work of developing difficulter for us and I expect a later merge as less time-consuming than a merge at this state.
> To get the VIN from the new EQ is already on my to do list for the next researches.
> I will check my mail server log, why the mail did not reach the Spam folder as well as my rspamd. It looks like it never was sent.
> Thanks
> Martin
> [1] From the Can-Ids the Smart EQ is a Renault Zoe and not a Smart. Lucky me there is a lot more documentation for Zoe and I can find the necessary ids and information faster than investigating from scratch.
> Gesendet: Montag, 24. Juni 2019 um 10:04 Uhr
> Von: "Mark Webb-Johnson" <mark at openvehicles.com>
> An: "OVMS Developers" <ovmsdev at lists.openvehicles.com>
> Betreff: Re: [Ovmsdev] iOS-App
> Martin,
> Welcome to the list.
> Not sure what problem you are having with your @hofgesang.de mailing address. I see one message on 2019-06-23 13:17:59 UTC that seemed to have been delivered (mailing list confirmation), but nothing else.
> Regarding the 4th generation ED/EQ support, that sounds great. If at all possible, please implement this by extending the existing Smart ED module, with a switch to control. This can either be a configuration option, or determined automatically via can bus traffic.
> For iPhone, the server setting is in the iOS Settings App (the gray gears App on the home screen of your phone), not in the ovms app. You will find a “Open Vehicles” area in that.
> On 24 Jun 2019, at 3:56 PM, Martin Hofgesang <martin.hofgesang at gmx.de <mailto:martin.hofgesang at gmx.de>> wrote:
> Hi all,
> first of all I want to say hello to you all, I am Martin, I started some days ago the work on a new vehicle for OVMS, the Smart ED/EQ (4th Generation), which has unfortunately other CAN-Ids than the existing module for Smart ED.
> Thomas who last changed the ED-module helped by doing the programmer stuff and I'm currently investigating the CAN-Ids and the information my EQ will give us through CAN-Bus.
> To test the module stability and use it in a normal way I would enjoy using the iPhone-App, but in the app I miss a setting for the server URL like it is in the Android app.
> Do I guess right, that the server setting is fixed to ovms.openvehicles.com <http://ovms.openvehicles.com/> and I can't use the german server from Dexter?
> How can I get an account as the openvehicles website and mailinglist is refusing to work with my mailadress ovms (a) hofgesang.de <http://hofgesang.de/> which I normally use for this project and would like to use here.
> Thanks & Regards
> Martin
> OvmsDev at lists.openvehicles.com <mailto:OvmsDev at lists.openvehicles.com>
> http://lists.openvehicles.com/mailman/listinfo/ovmsdev <http://lists.openvehicles.com/mailman/listinfo/ovmsdev>_______________________________________________ OvmsDev mailing list OvmsDev at lists.openvehicles.com http://lists.openvehicles.com/mailman/listinfo/ovmsdev <http://lists.openvehicles.com/mailman/listinfo/ovmsdev>_______________________________________________
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20190624/e0b5cd48/attachment.htm>
