    Thu Jun 20 02:35:40 HKT 2019
Mark,
catching up on this…
I remember doing an explanation of the additional callback mechanism background… yes, here it is:
http://lists.openvehicles.com/pipermail/ovmsdev/2018-July/005369.html
Am 12.06.19 um 15:00 schrieb Mark Webb-Johnson:
> I also see the filter system in canlog could be very useful as a general filtering system. I suggest to move that into the central CAN class, and allow such
> software filters to be attached to listeners, callbacks, and loggers.
> By refactoring this, I think we can get some very useful functionality.
> @Michael, one question, for you: What is the purpose of RegisterCallback (and the callbacks vs listeners, in general). Listeners get their frames delivered
> via a queue (so must have a task running). Callbacks are simple function callbacks running synchronously with the CAN task. From what I can see, the only user
> of callbacks is vehicle_twizy where CanResponder is set as the callback on CAN1. Why is that necessary, given that the standard vehicle object
> has IncomingFrameCan1() to receive frames. Is this required for performance (running synchronously with the CAN receive task), or some other reason why it
> can’t run from the vehicle task on queue receive of the frame? In other words, why can’t we just call CanResponder() from within IncomingFrameCan1()?
>> On 11 Jun 2019, at 8:49 PM, Mark Webb-Johnson <mark at webb-johnson.net <mailto:mark at webb-johnson.net>> wrote:
>> It has become a little duplicated:
>>     struct CAN_frame_t
>>       canbus*     origin;                   // Origin of the frame
>>       CAN_FIR_t   FIR;                      // Frame information record
>>       uint32_t    MsgID;                    // Message ID
>>       union
>>         uint8_t   u8[8];                    // Payload byte access
>>         uint32_t  u32[2];                   // Payload u32 access (Att: little endian!)
>>         uint64_t  u64;                      // Payload u64 access (Att: little endian!)
>>         } data;
>>       esp_err_t Write(canbus* bus=NULL, TickType_t maxqueuewait=0);  // bus: NULL=origin
>>     typedef struct
>>       uint32_t timestamp;
>>       canbus* bus;
>>       CAN_LogEntry_t type;
>>       union
>>         CAN_frame_t frame;
>>         CAN_status_t status;
>>         char* text;
>>       } CAN_LogMsg_t;
>>     typedef struct
>>       CAN_frame_t last;
>>       uint32_t rxcount;
>>       struct __attribute__((__packed__))
>>         struct {
>>           uint8_t Ignore:1;     // 0x01
>>           uint8_t Changed:1;    // 0x02
>>           uint8_t Discovered:1; // 0x04
>>           uint8_t :1;           // 0x08
>>           uint8_t :1;           // 0x10
>>           uint8_t :1;           // 0x20
>>           uint8_t :1;           // 0x40
>>           uint8_t :1;           // 0x80
>>           } b;
>>         uint8_t dc;             // Data bytes changed
>>         uint8_t dd;             // Data bytes discovered
>>         uint8_t spare;
>>         } attr;
>>       } re_record_t;
>> CAN_frame_t has origin for the can bus the message arrived on, while CAN_LogMsg_t has frame.origin and bus (presumably because bus is needed for status and
>> text messages).
>> Then we have candump and canlog virtual interfaces (canlog supports ’trace’ and ‘crtd’, while candump supports ‘crtd’ and ‘pap’).
>> The users of these higher level structures are RETOOLS and CANLOG. I suggest the following changes:
>>   * Have a single format conversion virtual class, and then initial implementations for pcap, crtd and trace. That can virtualise the conversion of a CAN
>>     message to be logged/transmitted/received to/from the external format. This can include a factory for registration of types (by textual name), as well as
>>     support functions for command registration (including whether they have support for reading, writing, or both). This just provides format conversion and
>>     does not provide any file handling or transmission functions. Canlog and Candump get merged to form this.
>>   * Perhaps base this on CAN_LogMsg_t, but I suggest a more generic name (perhaps CAN_message_t, to differentiate that this is a can message rather than a
>>     simple frame). It is CAN_frame_t + additional support for stats and general text messages.
>>   * Tidy up the CAN_LogMsg_t bus vs frame.origin issue.
>> Simply put, separate the formatting into a standalone virtual implementations, then leave retools and canlog to handle the actual RE stuff or file logging,
>> or whatever else is required with the data that gets converted.
>> Does that make sense?
>>> On 11 Jun 2019, at 3:01 PM, Michael Balzer <dexter at expeedo.de <mailto:dexter at expeedo.de>> wrote:
>>> Mark,
>>> when implementing the can log framework I introduced the CAN_LogMsg_t specifically to capture the original timestamp of the frame, so it wouldn't get lost if
>>> the logging task gets behind, and to transport other log data types than just frames to the loggers.
>>> I would also expect the RE tools stream to produce event info & statistics entries like can log does, as that is very helpful in analysing. Maybe rebasing
>>> candump on can log would be better?
>>> Am 11.06.19 um 08:37 schrieb Mark Webb-Johnson:
>>>> This really should be unified, and probably not too hard to do. Crazy to have two so similar frameworks. I think we can just have one virtual class for
>>>> converting CAN frames to/from other formats, and then implementations for CRTD, PCAP, etc.
>>>> I do remember that last time I looked at this, canlog used CAN_LogMsg_t, and candump used CAN_frame_t (with CAN_LogMsg_t having some other fields for
>>>> logging statistics, etc), and that made it non-trivial. Perhaps canlog should be built on top of candump?
>>>> I will have a look at it.
>>>> Regards, Mark.
>>>>> On 6 Jun 2019, at 4:06 PM, Michael Balzer <dexter at expeedo.de <mailto:dexter at expeedo.de>> wrote:
>>>>> Steve,
>>>>> Mark quoted from the RE tools candump_crtd class, which has its own crtd formatter.
>>>>> For the canlog framework I currently get the timestamp from esp_log_timestamp(). Should be easy to change that to gettimeofday().
>>>>> Regards,
>>>>> Michael
>>>>> Am 05.06.19 um 18:39 schrieb Stephen Casner:
>>>>>> Mark,
>>>>>> If by "unix julian time" you mean a timestamp like 1559751698 (the
>>>>>> time as I write this), than that is not what Greg and I have observed
>>>>>> in the CRTD logs.  Here are the first lines in our files:
>>>>>> 151766.574 CXX Info Type:crtd; Path:'/sd/gps.crtd'; Filter:1:100-100; Vehicle:TR2N;
>>>>>> 383603.293 CXX Info Type:crtd; Path:'/sd/location.crtd'; Filter:1:100-100; Vehicle:TR1N;
>>>>>> Yet OVMS does have the current time from NTP:
>>>>>> OVMS# time
>>>>>> Time Zone:
>>>>>> UTC Time:   2019-06-05 16:35:45 UTC
>>>>>> Local Time: 2019-06-05 16:35:45 GMT
>>>>>> Provider:   ntp
>>>>>> PROVIDER             STRATUM  UPDATE TIME
>>>>>> *ntp                       1      57 Wed Jun  5 16:35:44 2019
>>>>>> Who calls candump_crtd::get() with the timeval that goes into the
>>>>>> sprintf() you mention?
>>>>>>                                                       -- Steve
>>>>>> On Wed, 5 Jun 2019, Mark Webb-Johnson wrote:
>>>>>>> The CRTD timestamps should be unix julian time (not uptime). Produced by this:
>>>>>>> sprintf(m_buf,"%ld.%06ld %sR%s %0*X",
>>>>>>>   time->tv_sec, time->tv_usec,
>>>>>>>   busnumber,
>>>>>>>   (frame->FIR.B.FF == CAN_frame_std) ? "11":"29",
>>>>>>>   (frame->FIR.B.FF == CAN_frame_std) ? 3 : 8,
>>>>>>>   frame->MsgID);
>>>>>>> Once module gets time from the vehicle (or gps), it should show the correct timestamps.
>>>>>>> Regards, Mark.
>>>>>> OvmsDev mailing list
>>>>>> OvmsDev at lists.openvehicles.com <mailto:OvmsDev at lists.openvehicles.com>
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20190619/9cc5d6b7/attachment-0001.html>
