    Stephen Casner
    casner at acm.org
    Thu Jun  6 04:58:16 HKT 2019
Greg,
Attached are graphs of your data.  gregd.all.png shows all of the
data, and gregd.peak.png is the highest distance deviation of 369
meters, which is less than the default 500 meter threshold.
It looks like there is a diurnal pattern to the data with increased
deviations around midnight local time (the X axis times are UTC).
It also looks like your home elevation must be about 380 meters since
the altitude variable drops down to negative that amount frequently,
which would occur when that value is taken as zero (there is a special
case in the code to treat some values as zero).
I tried overlaying my data and yours, but there seems to be no
correlation between the peaks in my data and the peaks in yours.
Interestingly, my data does not show a similar diurnal pattern.
On Tue, 4 Jun 2019, Greg D. wrote:
> 200mb of logs sent to Steve for analysis....
> Greg
> Stephen Casner wrote:
> > Thanks.  For me, today's log was much quieter.  The maximum excursion
> > was 115 meters and it was roughly coincident with loss of lock.
> >                                                         -- Steve
> > On Fri, 31 May 2019, Greg D wrote:
> >> Ok.  I'll let it run for a few days and see what happens. Not planning to drive the car until next week.
> >> Greg
> >> On May 31, 2019 2:11:31 PM PDT, Stephen Casner <casner at acm.org> wrote:
> >>> On Fri, 31 May 2019, Greg D. wrote:
> >>>> Tried this, and am not getting anything written to the file system
> >>> (vfs
> >>>> ls /sd shows zero bytes in gps.crtd).  Did I miss some sort of setup
> >>> step?
> >>> Nothing gets written (or at least the file size as reported is not
> >>> updated) until the recording is stopped with "can log off".
> >>>                                                        -- Steve
Type: image/png
Desc:
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20190605/e3785d35/attachment-0002.png>
Type: image/png
Desc:
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20190605/e3785d35/attachment-0003.png>
