[Ovmsdev] New can logging
Sun Jul 28 20:52:25 HKT 2019
Michael,
Not sure what is going on. Here is what I get:
OVMS# log level verbose
Logging level for * set to verbose
OVMS# can log start monitor crtd
CAN logging to MONITOR active: Type:monitor Format:crtd Filter:off Vehicle:
Note: info logging is at debug log level, frame logging is at verbose, and errors as usual
I (58794) canlog-monitor: Now logging CAN messages to monitor
D (58794) canlog-monitor: 1564318162.354891 CXX OVMS CRTD
OVMS# can can1 start active 1000000
Can bus can1 started in mode active at speed 1000000bps
D (68894) events: Signal(power.can1.on)
OVMS# can can2 start active 1000000
Can bus can2 started in mode active at speed 1000000bps
D (73774) events: Signal(power.can2.on)
OVMS# can can1 tx standard 080 01 02 03 04
V (96934) canlog-monitor: 1564318200.493753 1T11 080 01 02 03 04
V (96934) canlog-monitor: 1564318200.494240 2R11 080 01 02 03 04
OVMS# can can1 tx standard 080 010203
V (108364) canlog-monitor: 1564318211.923843 1T11 080 03
V (108364) canlog-monitor: 1564318211.924243 2R11 080 03
Did you get a backtrace?
P.S. The data bytes in ‘can tx’ need to be space separated. Without that, it messed up the data, but still works for me.
> On 28 Jul 2019, at 7:27 PM, Michael Balzer <dexter at expeedo.de> wrote:
> Mark,
> is there a bug in the new can monitoring or am I doing something wrong?
> monitor mode:
> CAN logging to MONITOR active: Type:monitor Format:crtd Filter:off Vehicle:RT
> I (83919) canlog-monitor: Now logging CAN messages to monitor
> D (83919) canlog-monitor: 1564312407.926444 CXX OVMS CRTD
> ets Jun 8 2016 00:22:57
> rst:0x8 (TG1WDT_SYS_RESET),boot:0x3b (SPI_FAST_FLASH_BOOT)
> configsip: 0, SPIWP:0xee
> clk_drv:0x00,q_drv:0x00,d_drv:0x00,cs0_drv:0x00,hd_drv:0x00,wp_drv:0x00
> mode:DIO, clock div:2
> load:0x3fff0018,len:4
> load:0x3fff001c,len:4952
> load:0x40078000,len:7416
> load:0x40080000,len:8344
> entry 0x4008037c
> W (86) boot: PRO CPU has been reset by WDT.
> W (86) boot: WDT reset info: PRO CPU PC=0x4008aab8
> W (86) boot: WDT reset info: APP CPU PC=0x4009621a
> vfs mode:
> OVMS# can log start vfs crtd /sd/logs/can.crtd
> entry 0x4008037c
> W (86) boot: WDT reset info: APP CPU PC=0x400838cc
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20190728/e856ad27/attachment.html>
