[Ovmsdev] New can logging
Sun Jul 28 21:10:22 HKT 2019
I tried some more. It seems that the problem is with logging errors in crtd format. I didn’t see it because my bus had no errors.
Seems to be just a simple buffer overflow. I’ve committed a fix.
P.S. I have a relatively big update to can logging going through testing. Some standardisation of functionality for incoming data (such as whether to transmit or simulate it), and a can log playback system.
> On 28 Jul 2019, at 8:52 PM, Mark Webb-Johnson <mark at webb-johnson.net> wrote:
> Michael,
> Not sure what is going on. Here is what I get:
> OVMS# log level verbose
> Logging level for * set to verbose
> OVMS# can log start monitor crtd
> CAN logging to MONITOR active: Type:monitor Format:crtd Filter:off Vehicle:
> Note: info logging is at debug log level, frame logging is at verbose, and errors as usual
> I (58794) canlog-monitor: Now logging CAN messages to monitor
> D (58794) canlog-monitor: 1564318162.354891 CXX OVMS CRTD
> OVMS# can can1 start active 1000000
> Can bus can1 started in mode active at speed 1000000bps
> D (68894) events: Signal(power.can1.on)
> OVMS# can can2 start active 1000000
> Can bus can2 started in mode active at speed 1000000bps
> D (73774) events: Signal(power.can2.on)
> OVMS# can can1 tx standard 080 01 02 03 04
> V (96934) canlog-monitor: 1564318200.493753 1T11 080 01 02 03 04
> V (96934) canlog-monitor: 1564318200.494240 2R11 080 01 02 03 04
> OVMS# can can1 tx standard 080 010203
> V (108364) canlog-monitor: 1564318211.923843 1T11 080 03
> V (108364) canlog-monitor: 1564318211.924243 2R11 080 03
> Did you get a backtrace?
> Regards, Mark
> P.S. The data bytes in ‘can tx’ need to be space separated. Without that, it messed up the data, but still works for me.
>> On 28 Jul 2019, at 7:27 PM, Michael Balzer <dexter at expeedo.de <mailto:dexter at expeedo.de>> wrote:
>> Mark,
>> is there a bug in the new can monitoring or am I doing something wrong?
>> monitor mode:
>> CAN logging to MONITOR active: Type:monitor Format:crtd Filter:off Vehicle:RT
>> I (83919) canlog-monitor: Now logging CAN messages to monitor
>> D (83919) canlog-monitor: 1564312407.926444 CXX OVMS CRTD
>> ets Jun 8 2016 00:22:57
>> rst:0x8 (TG1WDT_SYS_RESET),boot:0x3b (SPI_FAST_FLASH_BOOT)
>> configsip: 0, SPIWP:0xee
>> clk_drv:0x00,q_drv:0x00,d_drv:0x00,cs0_drv:0x00,hd_drv:0x00,wp_drv:0x00
>> mode:DIO, clock div:2
>> load:0x3fff0018,len:4
>> load:0x3fff001c,len:4952
>> load:0x40078000,len:7416
>> load:0x40080000,len:8344
>> entry 0x4008037c
>> W (86) boot: PRO CPU has been reset by WDT.
>> W (86) boot: WDT reset info: PRO CPU PC=0x4008aab8
>> W (86) boot: WDT reset info: APP CPU PC=0x4009621a
>> vfs mode:
>> OVMS# can log start vfs crtd /sd/logs/can.crtd
>> entry 0x4008037c
>> W (86) boot: WDT reset info: APP CPU PC=0x400838cc
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20190728/d726dba8/attachment-0001.html>
