[Ovmsdev] esp-idf v3.3
Mon Jul 22 03:33:11 HKT 2019
Update is pushed.
Don't forget to do a submodule update in the esp-idf, I also recommend doing a "make clean" before the next build.
Use the defaults for new config options, except:
- disable SPIRAM_BANKSWITCH_ENABLE (bank switching for >4MiB external RAM)
- disable FATFS_ALLOC_PREFER_EXTRAM (Perfer external RAM when allocating FATFS)
Am 20.07.19 um 23:21 schrieb Michael Balzer:
> FYI: I've merged the current v3.3 status and am now running the new build (toolchain still 1.22.0-93-gf6c4cdf) on my modules.
> I though it would be easier to merge v3.2 first, but that didn't work out. The current v3.2 status seems to have a bug, it wouldn't link due to too many
> segments. The segments have been introduced by a wifi blob update to support a new wifi IRAM optimization, but that needs a linker script & esptool update as
> well, that seems to be available only in the v3.3 branch.
> So I merged v3.3 directly afterwards, and that builds without issues.
> So far I haven't noticed any relevant problems running the new build. On stopping the wifi module, two event errors get logged, and the AP network interface
> remains configured as up:
> OVMS# wifi mode off
> Stopping wifi station...
> I (1307252) esp32wifi: Stopping WIFI station
> I (1307252) netmanager: Interface priority is pp3 (10.170.195.13/255.255.255.255 gateway 10.64.64.64)
> I (1307252) netmanager: Set DNS#2 0.0.0.0
> I (1307252) netmanager: WIFI client down (with MODEM up): reconfigured for MODEM priority
> I (1307252) wifi: state: run -> init (0)
> I (1307262) wifi: pm stop, total sleep time: 1100678913 us / 1301859253 us
> I (1307262) wifi: new:<1,0>, old:<1,1>, ap:<1,1>, sta:<1,0>, prof:1
> E (1307262) event: system_event_sta_disconnected_handle_default 294 esp_wifi_internal_reg_rxcb ret=0x3014
> E (1307262) event: system_event_ap_stop_handle_default 223 esp_wifi_internal_reg_rxcb ret=0x3014
> W (1307262) netmanager: CleanupConnections: can't get AP station list
> I (1307272) wifi: flush txq
> I (1307272) wifi: stop sw txq
> I (1307272) wifi: lmac stop hw txq
> I (1307292) time: Network was reconfigured: restarting SNTP client
> I (1307322) netmanager: Set DNS#2 0.0.0.0
> I (1307322) esp32wifi: STA disconnected with reason 8
> I (1307352) netmanager: Set DNS#2 0.0.0.0
> I (1307392) netmanager: Set DNS#2 0.0.0.0
> I (1307392) netmanager: WIFI access point is down
> I (1307392) esp32wifi: AP stopped
> OVMS# net status
> Interface#3: pp3 (ifup=1 linkup=1)
> IPv4: 10.170.195.13/255.255.255.255 gateway 10.64.64.64
> Interface#2: ap2 (ifup=1 linkup=1)
> IPv4: 192.168.4.1/255.255.255.0 gateway 192.168.4.1
> DNS: 192.168.2.1 192.168.2.1
> Default Interface: pp3 (10.170.195.13/255.255.255.255 gateway 10.64.64.64)
> OVMS#
> But wifi is off, and after starting the wifi network again, everything works, so that's a minor issue.
> I'll do some more tests tomorrow, then push the update.
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20190721/d0e485fb/attachment.html>
