[Ovmsdev] Trying to get a new car in, CRTD, CANbus and all
Craig Leres leres at xse.com
Fri Jul 19 01:10:45 HKT 2019
On 2019-07-16 16:47, Mark Webb-Johnson wrote:
> One comment:
>     The new format CRTD produced by OVMS includes bus# prefix. So the
>     records look like ‘1R11’ or ‘2R11’ (for bus #1 and bus #2,
>     respectively). SavvyCAN currently supports only the old format ‘R11’
>     CRTD. If you want to load these into SavvyCAN, you will need to
>     modify the CRTD log file.
> There is currently experimental support for SavvyCAN server mode in the
> latest bleeding edge OVMS:
>     OVMS# can log start tcpserver gvret-b :23
> Then put in the wifi IP address of the OVMS into the SavvyCAN server
> connection, and you should start to see live data from OVMS. This is
> experimental, and still a work-in-progress, but basic functionality is
> working.
This is really cool! I found it pretty easy to crash the savvycan app
itself and some random gm dbc files I can across didn't seem to decode
any of my frames but this looks very powerful.
		Craig
