[Ovmsdev] Trying to get a new car in, CRTD, CANbus and all
Wed Jul 17 09:47:29 HKT 2019
One comment:
The new format CRTD produced by OVMS includes bus# prefix. So the records look like ‘1R11’ or ‘2R11’ (for bus #1 and bus #2, respectively). SavvyCAN currently supports only the old format ‘R11’ CRTD. If you want to load these into SavvyCAN, you will need to modify the CRTD log file.
There is currently experimental support for SavvyCAN server mode in the latest bleeding edge OVMS:
OVMS# can log start tcpserver gvret-b :23
Then put in the wifi IP address of the OVMS into the SavvyCAN server connection, and you should start to see live data from OVMS. This is experimental, and still a work-in-progress, but basic functionality is working.
> On 15 Jul 2019, at 10:43 PM, Julien “JaXX” Banchet <jaxx at jaxx.org> wrote:
> Hi everyone, and happy summer to all !
> So, sold my Twizy a month ago, the OVMSv3.1 has left with it, got a VW e-UP! a little bit before and received a v3.2 last week.
> Threw away a few microSDs but got a CRTD log this afternoon.
> While I have the weird impression 1335 lines and 55kB ( https://pastebin.com/FAZqnzie ) for a 30 minute drive back from work seems very short, I tried reading it in SavvyQT but it “salvages” only the first 35 lines.
> (30 minutes kinda full left aside the wipers, ignition off, on, launch, lights, windows, reversing, and even blinkers that Parisians try to avoid using for some odd reason, so yeah, 1335 lines, that’s not even a frame per second, something is missing)
> No DBC found on the interwebz for volkswagen’s AA/12 platform, so I’m in for making a first probably ? That is if the sole CANBus connected got anything worthy (OBDII vehicle module used)
> I have understood VAG cars are a bit different in a way, I wouldn’t be surprised accessing VW busses need a bit of help :)
> Anybody around with a bit of knowledge with these cars ?
> Best,
> JaXX./.
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20190717/f87a095f/attachment.html>
