[Ovmsdev] Attention: esp-idf upgrade still breaks configuration
Fri Jan 25 02:50:05 HKT 2019
I could test the modem now: modem & PPP is basically working, but it doesn't deliver the mobile network DNS. That is clearly an issue of the new esp-idf, not
the Hologram SIM, as it works perfectly with the old esp-idf.
The network manager gets all signals as expected and tries to save & restore the modem DNS, but it's just 0.0.0.0 on every connect.
When setting a manual DNS, modem connectivity & switching wifi/modem works.
I haven't found a matching issue on github yet.
Am 23.01.19 um 12:35 schrieb Mark Webb-Johnson:
> Great news (the bug fix, not the new wifi bug).
> Looking forward to seeing this finally arrive. The last annoying framework bug for me is this wifi unable to reconnect issue.
>> On 23 Jan 2019, at 4:17 AM, Michael Balzer <dexter at expeedo.de <mailto:dexter at expeedo.de>> wrote:
>> Wifi AP mode is broken. A fix should be available in some days:
>> https://github.com/espressif/esp-idf/issues/2915#issuecomment-452606571
>> I haven't been able to test the modem yet. It seems to work but my test SIM ran out of balance, so I need to wait for the payment process to finish.
>> Apart from that it works pretty well so far.
>> Am 22.01.19 um 17:43 schrieb Michael Balzer:
>>> Dmitry found out we had a bad timing with our merge. The bug was fixed by him just five days later:
>>> https://github.com/espressif/esp-idf/commit/82eca97300410dd743de7f116836879cf3cdc6ba
>>> I have merged the latest upstream HEAD locally now. It builds correctly, with just one little issue in the Kconfig for Smart ED, and seems to work correctly
>>> as well. I'll do some testing now.
>>> Am 27.12.18 um 11:03 schrieb Michael Balzer:
>>>> Update: I managed to reproduce the bug, and Dmitry's assumption is correct.
>>>> The wear leveling system attempts to do an update when mounting a partition formatted with the old version. That update fails and leads to the next reboot
>>>> failing to mount the partition.
>>>> So the WL update process needs to be fixed.
>>>> Regards,
>>>> Michael
>>>> Am 27.11.18 um 22:35 schrieb Michael Balzer:
>>>>> @all: we need some help on this.
>>>>> Dmitry has asked us to verify an assumption about the source of the problem. Unfortunately, my module has decided to not show the bug anymore.
>>>>> Can anyone a) reproduce the bug and b) check Dmitry's code change? The code change is very simple:
>>>>>     https://github.com/espressif/esp-idf/issues/2730#issuecomment-441928779
>>>>> …that's in file esp-idf/components/wear_levelling/WL_Flash.cpp line 183.
>>>>> Chances are the bug is more frequently present on V3.1 first batch modules.
>>>>> _To test a build including the bug, do_:
>>>>>     OVMS# config backup /sd/cfgbackup.zip
>>>>>     ~/…/esp-idf> git checkout 5afc1b0cbbcd5903744cd2948ee235b7016eeede
>>>>>     ~/…/esp-idf> git merge --no-commit 9d609af54c63e7f949a4fbc43d4f1c13b57f49d8
>>>>>     ~/…/esp-idf> git submodule update --recursive
>>>>>     ~/…/OVMS.V3> git checkout c3c908c00a09c4a841d1fec115be785c8f486270
>>>>>     ~/…/OVMS.V3> make app-flash
>>>>> Then do some reboots of the module.
>>>>> If the bug shows up, usually the second reboot already will result in a lost configuration. You'll see some warnings in the boot process (mount failure),
>>>>> and the prompt will directly be "#" as no module password is in place.
>>>>> If that happens, rebuild after applying the change as described by Dmitry, restore your config (see below), check if the bug is gone. If it isn't, the
>>>>> change _definitely doesn't work_.
>>>>> If it's gone, as the bug can stop showing up, you need to revert Dmitry's change and check once again if the bug reappears. If it does, the change
>>>>> _definitely works_.
>>>>> If the bug doesn't reappear, you need to switch off the module for some hours, then redo the above steps.
>>>>> _Note on restoring the config backup_: as my later restore fix isn't included in that version, you may need to create the events directory manually:
>>>>>     OVMS# vfs mkdir /store/events
>>>>>     OVMS# config restore /sd/cfgbackup.zip <password>
>>>>> To return to normal build setup:
>>>>>     ~/…/esp-idf> git checkout -f master
>>>>>     ~/…/OVMS.V3> git checkout master
>>>>> Please report definitive results directly to Dmitry in the issue #2730.
>>>>> Thanks,
>>>>> Michael
>>>>> Am 27.11.18 um 02:02 schrieb Mark Webb-Johnson:
>>>>>> I think unmount should be on the system.shutdown event. That would be after system.shuttingdown and the MyBoot.RestartPending/RestartReady control steps.
>>>>>> That means if a component really wants to write to config (or elsewhere on /store), it should do it during system.shuttingdown event (and optionally do
>>>>>> the MyBoot.RestartPending(TAG) and MyBoot.RestartReady(TAG) thing, like simcom).
>>>>>> As you say, that doesn’t address the crash-during-shuttingdown issue, but can be done in a very component manner. No changes to MyBoot - all done in
>>>>>> ovms_config. Or just hard-code the /store unmount before esp_restart().
>>>>>> Regards, Mark.
>>>>>>> On 27 Nov 2018, at 12:47 AM, Michael Balzer <dexter at expeedo.de <mailto:dexter at expeedo.de>> wrote:
>>>>>>> Dimitris question about unclean shutdowns let me check our reboot code, and we actually do not take care of unmounting the config store.
>>>>>>> While my crash observations do not look like crash/clean makes a difference to this bug, I still think we should do that.
>>>>>>> The simple solution would be to do this last, in Boot::boot_shutdown_done() just before the esp_restart(), but that does not take care of crashes during
>>>>>>> shutdown, which still are too frequent.
>>>>>>> How about unmounting /store ASAP after the shuttingdown event (i.e. normal shutdown handling)?
>>>>>>> Writing to the config would then have no effect during shutdown, but do we actually need (want) that to be possible?
>>>>>>> Regards,
>>>>>>> Michael
>>>>>>> Am 25.11.18 um 03:12 schrieb Mark Webb-Johnson:
>>>>>>>> I second this. A fantastic effort, Michael.
>>>>>>>> The log you provided on the GitHub issue looks really helpful, and I see Dimitri has replied:
>>>>>>>>           dmitry1945 <https://github.com/dmitry1945> commented 6 hours ago <https://github.com/espressif/esp-idf#issuecomment-441391665>
>>>>>>>>     Thank you @dexterbg <https://github.com/dexterbg>, the place is clear.
>>>>>>>> Hopefully Dimitri can find the issue from here. So many little bugs in wifi and bluetooth stacks causing us random issues - it would be helpful to be
>>>>>>>> able to update to the latest IDF.
>>>>>>>> Thanks, and Regards,
>>>>>>>> Mark.
>>>>>>>>> On 25 Nov 2018, at 3:22 AM, Stephen Casner <casner at acm.org <mailto:casner at acm.org>> wrote:
>>>>>>>>> Michael -- Kudos for this Herculean effort -- Steve
>>>>>>>>> On Sat, 24 Nov 2018, Michael Balzer wrote:
>>>>>>>>>> Narrowing this down is a real PITA. The effect sometimes stops to occur, I then need to leave the module powered down for a while to get the effect back.
>>>>>>>>>> Sometimes 1 hour is sufficient, currently it's been off for 2 hours and still works. I had a test window yesterday evening, one this morning and one
>>>>>>>>>> in the
>>>>>>>>>> afternoon. Temperature is most probably irrelevant, as the last power downs were outside in ~4-5 °C to rule this out.
>>>>>>>>>> So as a "passed" can always be a false positive I need to validate every passed step by switching back to a failing version and see if that still fails.
>>>>>>>>>> It seems I now have to wait until tomorrow for the next test window, but I have bisected down to this range of just 8 commits:
>>>>>>>>>> balzer at leela:~/esp/esp-idf> git rev-list 9d609af54c63e7f949a4fbc43d4f1c13b57f49d8 ^9d2f7c60d9aef9860c61c2756318ada68c80fddf
>>>>>>>>>> f392727abf7d56490c2f33127a59bfac42c937e0
>>>>>>>>>> e834d6fffc23a6fcfc0d2e871c9235417a7fb48f
>>>>>>>>>> 35842d02abb5f574aaab466d46081a232fdd20a6
>>>>>>>>>> f05f3fbde87a9ce45c6818f71b49cd13888fd457
>>>>>>>>>> a6d6c58ecadb9759a0bacf35cd7332ac641e598d
>>>>>>>>>> 321b1e02052de95db60ddce87eecce5f9e04e9b8
>>>>>>>>>> 40486c872345584d34949b3ce83f9e956a7eea13
>>>>>>>>>> ...with 9d609af54c63e7f949a4fbc43d4f1c13b57f49d8 being the last identified bad commit, and 9d2f7c60d9aef9860c61c2756318ada68c80fddf being the last good.
>>>>>>>>>> If I should guess now, it's probably one of Dmitry's commits on the wear leveling code.
>>>>>>>>>> Regards,
>>>>>>>>>> Michael
>>>>>>>>>> Am 23.11.18 um 17:20 schrieb Michael Balzer:
>>>>>>>>>>> It's not a timing issue, I've let it reboot about 30 times without any successful mount after the first failure.
>>>>>>>>>>> Going into bisecting now...
>>>>>>>>>>> Am 23.11.18 um 15:54 schrieb Mark Webb-Johnson:
>>>>>>>>>>>>> It may actually not be a corruption of the filesystem but some timing issue on the mount procedure. To test that we could disable the auto
>>>>>>>>>>>>> formatting on
>>>>>>>>>>>>> mount failures.
>>>>>>>>>>>> True.
>>>>>>>>>>>> A couple of Espressif guys have jumped on the issue, and I have provided some more information for them. I think key will be reproducing it.
>>>>>>>>>>>>> The issue may also be dependant on the hardware version, i.e. it could be caused by the bug that caused the SD speed issue on the first 3.1 batch.
>>>>>>>>>>>> That was definitely a hardware issue with the CP2102 chip. I don't think related to ESP in any way.
>>>>>>>>>>>> Regards, Mark.
>>>>>>>>>>>>> On 23 Nov 2018, at 10:34 PM, Michael Balzer <dexter at expeedo.de <mailto:dexter at expeedo.de> <mailto:dexter at expeedo.de>> wrote:
>>>>>>>>>>>>> formatting on
>>>>>>>>>>>>> mount failures.
>>>>>>>>>>>>> I only have tried the idf update on my batch 1 module (my bench / development module). I think most of our edge testers also have that version.
>>>>>>>>>>>>> Regards,
>>>>>>>>>>>>> Michael
>>>>>>>>>>>>> Am 23.11.18 um 02:32 schrieb Mark Webb-Johnson:
>>>>>>>>>>>>>> I have raised the following github issue to Espressif:
>>>>>>>>>>>>>>        Environment
>>>>>>>>>>>>>>      * Development Kit: none
>>>>>>>>>>>>>>      * Kit version (for WroverKit/PicoKit/DevKitC): none
>>>>>>>>>>>>>>      * Module or chip used: ESP32-WROVER 16MB
>>>>>>>>>>>>>>      * IDF version (run |git describe --tags| to find it): v3.2-beta1-208-g0d7f2d77c
>>>>>>>>>>>>>>      * Build System: make
>>>>>>>>>>>>>>      * Compiler version (run |xtensa-esp32-elf-gcc --version| to find it): (crosstool-NG crosstool-ng-1.22.0-80-g6c4433a) 5.2.0
>>>>>>>>>>>>>>      * Operating System: macOS
>>>>>>>>>>>>>>      * Power Supply: USB
>>>>>>>>>>>>>>        Problem Description
>>>>>>>>>>>>>>    TLDR: Between May and July 2018 a change was made to esp idf master that is causing corruption on FAT filesystems mounted on SPI flash.
>>>>>>>>>>>>>>    Our project uses a partitions.csv as follows:
>>>>>>>>>>>>>>    |# Name, Type, SubType, Offset, Size nvs, data, nvs, 0x9000, 0x4000 otadata, data, ota, 0xd000, 0x2000 phy_init, data, phy, 0xf000, 0x1000
>>>>>>>>>>>>>> factory,
>>>>>>>>>>>>>>    app, factory, 0x10000, 4M ota_0, app, ota_0, , 4M ota_1, app, ota_1, , 4M store, data, fat, , 1M |
>>>>>>>>>>>>>>    The 'store' partition is formatted as FAT, as follows:
>>>>>>>>>>>>>>    esp_vfs_fat_mount_config_t m_store_fat;
>>>>>>>>>>>>>>    wl_handle_t m_store_wlh;
>>>>>>>>>>>>>>    memset(&m_store_fat,0,sizeof(esp_vfs_fat_sdmmc_mount_config_t));
>>>>>>>>>>>>>>    m_store_fat.format_if_mount_failed = true;
>>>>>>>>>>>>>>    m_store_fat.max_files = 5;
>>>>>>>>>>>>>>    esp_vfs_fat_spiflash_mount("/store", "store", &m_store_fat, &m_store_wlh);
>>>>>>>>>>>>>>    We have previously used a clone of esp idf master, dated around May 22 2018, without issues. The partition is very reliable.
>>>>>>>>>>>>>>    However, on Jul 6 2018, we updated our clone to use the latest esp idf master at that time. Shortly afterwards, users started to report that their
>>>>>>>>>>>>>>    'store' filesystem contents were corrupted. We rolled back.
>>>>>>>>>>>>>>    We have now tried again (updating on Oct 20 2018 to v3.2-beta1-208-g0d7f2d77c) and immediately had the same issue. Random corruption of FAT
>>>>>>>>>>>>>> filesystem
>>>>>>>>>>>>>>    in SPI flash.
>>>>>>>>>>>>>>          Expected Behavior
>>>>>>>>>>>>>>    No corruption of FAT filesystem.
>>>>>>>>>>>>>>          Actual Behavior
>>>>>>>>>>>>>>    Corruption of FAT filesystem.
>>>>>>>>>>>>>>          Steps to reproduce
>>>>>>>>>>>>>>     1. Create a partition in SPI flash, and mount FAT filesystem
>>>>>>>>>>>>>>     2. Read and write to files on FAT filesystem
>>>>>>>>>>>>>>     3. Reboot
>>>>>>>>>>>>>>     4. Observe random corruption and unmountable filesystem
>>>>>>>>>>>>>>          Code to reproduce this issue
>>>>>>>>>>>>>>        Debug Logs
>>>>>>>>>>>>>>    n/a
>>>>>>>>>>>>>>        Other items if possible
>>>>>>>>>>>>>>    Please advise if you need anything further.
>>>>>>>>>>>>>> I think the timeline is correct (the issue is in esp idf master some time between May and July 2018), but please let me know if you know
>>>>>>>>>>>>>> differently (or
>>>>>>>>>>>>>> update the github issue with your comments).
>>>>>>>>>>>>>> Regards, Mark
>>>>>>>>>>>>>>> On 23 Nov 2018, at 6:19 AM, Michael Balzer <dexter at expeedo.de <mailto:dexter at expeedo.de> <mailto:dexter at expeedo.de>> wrote:
>>>>>>>>>>>>>>> esp-idf and OVMS branches are back to the working version.
>>>>>>>>>>>>>>> In case you also lost your config:  I also just fixed a bug on restoring into an empty /store partition.
>>>>>>>>>>>>>>> Regards,
>>>>>>>>>>>>>>> Michael
>>>>>>>>>>>>>>> Am 22.11.18 um 22:34 schrieb Michael Balzer:
>>>>>>>>>>>>>>>> See https://github.com/openvehicles/Open-Vehicle-Monitoring-System-3/pull/165
>>>>>>>>>>>>>>>> I'll reset both master branches now.
>>>>>>>>>>>>>>>> If you're about to pull, please wait until I've reverted the branches.
>>>>>>>>>>>>>>>> Regards,
>>>>>>>>>>>>>>>> Michael
>>>>>>>>>>>>>>> Michael Balzer * Helkenberger Weg 9 * D-58256 Ennepetal
>>>>>>>>>>>>>>> Fon 02333 / 833 5735 * Handy 0176 / 206 989 26
>>>>>>>>>>>>>>> _______________________________________________
>>>>>>>>>>>>>>> OvmsDev mailing list
>>>>>>>>>>>>>>> OvmsDev at lists.openvehicles.com <mailto:OvmsDev at lists.openvehicles.com> <mailto:OvmsDev at lists.openvehicles.com>
>>>>>>>>>>>>>>> http://lists.openvehicles.com/mailman/listinfo/ovmsdev
>>>>>>>>>                                                        -- Steve_______________________________________________
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20190124/6a61829a/attachment.htm>
