[Ovmsdev] Crash debug
Sun Jan 20 20:53:49 HKT 2019
When you ‘make’, it should set defaults for kconfig.
Anyway, stack of 12288 definitely solves this problem.
Mark
> On 20 Jan 2019, at 8:47 PM, Tamás Kovács <kommykt at gmail.com> wrote:
> I don't updated the sdkconfig file, now use the latest working, no crash. In old missing stack size row.
> Mark Webb-Johnson <mark at webb-johnson.net> ezt írta (időpont: 2019. jan. 20., V, 13:31):
>> What size stack have you defined for Duktape? Should be the default 12288.
>> Regards, Mark
>>> On 20 Jan 2019, at 8:04 PM, Olivier <ogrums at gmail.com> wrote:
>>> Hello Tamás,
>>> Same bug here, with the last release, my guest is because we load in memory to many thing.
>>> To be able to start the device I choose Vehicle Empty and then chose the right one or you can disable duktape on sdkconfig (or by make menuconfig)
>>> # Library Support
>>> CONFIG_OVMS_SC_JAVASCRIPT_NONE=y
>>> CONFIG_OVMS_SC_JAVASCRIPT_DUKTAPE=
>>> regards,
>>> Olivier
>>>> Le dim. 20 janv. 2019 à 12:38, Tamás Kovács <kommykt at gmail.com> a écrit :
>>>> How can i debug what's the problem? I get the following crash (source code on my github: https://github.com/KommyKT/Open-Vehicle-Monitoring-System-3): I used the latest openvehicle updates + my mitsubishi code. I create the firwmare with make app, then upload to my NAS and update via OTA update.
>>>>> Welcome to the Open Vehicle Monitoring System (OVMS) - Async Console
>>>>> Firmware: 3.1.011-244-g1a15127d-dirty/ota_0/main
>>>>> Hardware: OVMS WIFI BLE BT cores=2 rev=ESP32/1
>>>>> OVMS> ***ERROR*** A stack overflow in task OVMS DukTape has been detected.
>>>>> abort() was called at PC 0x40096278 on core 1
>>>>> Backtrace: 0x40096064:0x3ffc11b0 0x4009625f:0x3ffc11d0 0x40096278:0x3ffc11f0 0x40091704:0x3ffc1210 0x40093768:0x3ffc1230 0x4009371e:0x3ffc1250 0x7aad5675:0x3f81d8f4
>>>>> Rebooting...
>>>>> ets Jun 8 2016 00:22:57
>>>>> rst:0xc (SW_CPU_RESET),boot:0x3b (SPI_FAST_FLASH_BOOT)
>>>>> configsip: 0, SPIWP:0xee
>>>>> clk_drv:0x00,q_drv:0x00,d_drv:0x00,cs0_drv:0x00,hd_drv:0x00,wp_drv:0x00
>>>>> mode:DIO, clock div:2
>>>>> load:0x3fff0018,len:4
>>>>> load:0x3fff001c,len:4960
>>>>> ho 0 tail 12 room 4
>>>>> load:0x40078000,len:7416
>>>>> ho 0 tail 12 room 4
>>>>> load:0x40080000,len:8344
>>>>> entry 0x4008037c
>>>>> I (882) spiram: SPI RAM mode: flash 40m sram 40m
>>>>> I (882) spiram: PSRAM initialized, cache is in low/high (2-core) mode.
>>>>> I (883) cpu_start: Pro cpu up.
>>>>> I (887) cpu_start: Starting app cpu, entry point is 0x40081668
>>>>> I (877) cpu_start: App cpu up.
>>>>> I (1785) spiram: SPI SRAM memory test OK
>>>>> I (1786) heap_init: Initializing. RAM available for dynamic allocation:
>>>>> I (1786) heap_init: At 3FFAE6E0 len 00001920 (6 KiB): DRAM
>>>>> I (1793) heap_init: At 3FFBCDA8 len 00023258 (140 KiB): DRAM
>>>>> I (1798) heap_init: At 3FFE0440 len 00003BC0 (14 KiB): D/IRAM
>>>>> I (1805) heap_init: At 3FFE4350 len 0001BCB0 (111 KiB): D/IRAM
>>>>> I (1811) heap_init: At 4009D560 len 00002AA0 (10 KiB): IRAM
>>>> OvmsDev mailing list
> Üdvözlettel:
> Kovács Tamás
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20190120/d9b73cda/attachment.htm>
