[Ovmsdev] Problem with Mac OS Mojave
Stephen Casner
casner at acm.org
Sun Jan 20 04:57:53 HKT 2019
Mark,
Thanks, indeed the fix was to let the App Store update Xcode. That
takes longer than the OS update! And why should the OS update
invalidate the already-installed version of Xcode?
I had started to do the update last night, but a quick (mis-)read of
some posts in the espressif forum about this led me to believe that
it might be necessary to use Xcode 9 rather than 10.
> Steve,
> Perhaps your Xcode needs to be updated? Apple often releases new Xcode with each new major OSX update. Also, double-check Xcode command line tools have been installed.
> > On 19 Jan 2019, at 4:33 PM, Stephen Casner <casner at acm.org> wrote:
> > I've been running on Mac OS Yosemite for some time and have avoided
> > updating to newer releases for various reasons, but I was forced to
> > update to Mojave in order to run this year's TurboTax. But that broke
> > my ESP-IDF build procedure:
> > auge25> make clean
> > sh: line 1: 1212 Abort trap: 6 /Applications/Xcode.app/Contents/Developer/usr/bin/xcodebuild -sdk '' -find make 2> /dev/null
> > make: error: unable to find utility "make", not a developer tool or in PATH
> > Have any of you encounted this and fixed it?
> > -- Steve
