[Ovmsdev] Leaf door control (was: OVMS v3 v3.2.001 Over-the-Air firmware update)
ovms
ovms at topphemmelig.no
Mon Feb 4 20:11:38 HKT 2019
Yes, I also used the valet/homelink function to lock the doors since the can-bus stops receiving after some time and the lock/unlock button is only one button that does not change status.
-Stein Arne-
On 2019-02-04 13:05, Robin O'Leary <ovmsdev at caederus.org> wrote:
> On Mon, Feb 04, 2019 at 11:28:20AM +0100, ovms wrote: > Attached is the two files I have changed before compiling. Can you use these two files and do a diff between yours and mine? There was an earlier thread about this: http://lists.openvehicles.com/pipermail/ovmsdev/2018-May/005167.html I did a branch for it back then, which I just updated: https://github.com/caederus-ovms/Open-Vehicle-Monitoring-System-3/tree/leaf-doorlock However, I don't think the code is quite right, either on the branch or in Stein Arne Sordal's version; the latter also adds Homelink button 2 which duplicates the unlock function and CommandActivateValet which duplicates the lock function. Both versions should probably also address the issue Tom mentioned, (sending the lock/unklock command multiple times, if it isn't necessary): http://lists.openvehicles.com/pipermail/ovmsdev/2018-May/005182.html _______________________________________________ OvmsDev mailing list OvmsDev at lists.openvehicles.com http:!
//lists.o
penvehicles.com/mailman/listinfo/ovmsdev
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20190204/fe29998c/attachment.htm>
