[Ovmsdev] Leaf door control (was: OVMS v3 v3.2.001 Over-the-Air firmware update)
Robin O'Leary ovmsdev at caederus.org
Mon Feb 4 20:04:48 HKT 2019
On Mon, Feb 04, 2019 at 11:28:20AM +0100, ovms wrote:
> Attached is the two files I have changed before compiling. Can you use these two files and do a diff between yours and mine?
There was an earlier thread about this:
http://lists.openvehicles.com/pipermail/ovmsdev/2018-May/005167.html
I did a branch for it back then, which I just updated:
https://github.com/caederus-ovms/Open-Vehicle-Monitoring-System-3/tree/leaf-doorlock
However, I don't think the code is quite right, either on the branch or
in Stein Arne Sordal's version; the latter also adds Homelink button 2
which duplicates the unlock function and CommandActivateValet which
duplicates the lock function.
Both versions should probably also address the issue Tom mentioned,
(sending the lock/unklock command multiple times, if it isn't necessary):
http://lists.openvehicles.com/pipermail/ovmsdev/2018-May/005182.html
