[Ovmsdev] OTA download incremental progress no longer happens
Sat Feb 16 22:59:54 HKT 2019
How are you doing the download? Web interface shell, ssh, or usb console?
Which command are you using?
> On 16 Feb 2019, at 2:22 PM, Craig Leres <leres at xse.com> wrote:
> When doing an OTA download the download progress used to incrementally
> display, e.g. it would start with:
>    Processing… (do not interrupt, may take some minutes)
> and then slowly spit out a bunch of lines like this:
>    Downloading... (100029 bytes so far)
> And then finish with a form offering to reboot or whatever. This has
> been broken for a few versions now. Basically when you start the OTA
> download you get the initial dialog and then nothing happens until the
> download completes and then you see the rest of the output at once.
> I normally use firefox but the behavior is the same with chorme.
>        Craig
