[Ovmsdev] version 3.2.007: Crash on boot
Greg D.
gregd2350 at gmail.com
Wed Dec 11 11:33:19 HKT 2019
Hi folks,
Well, the module updated to 3.2.007 last night. I just checked on it,
and it appears that it didn't exactly survive. Crashed while running
the autoconfig script. Log with two cycles attached.
I tried renaming the /store/events directory to /store/was_events since
it seems like Duktape was getting in the way, but that didn't resolve
the crash. I manually enabled wifi so I could manage the module, and
moved it back to 3.2.005 from the other partition. Seems stable again.
The car is going into the Service Center tomorrow (the perennial issue
with 1146 alerts), so I need to have the module stable so that I can
keep an eye on it. Going to leave it on 3.2.005 for now, unless someone
has a quick fix in the next few hours...
Otherwise, any ideas for troubleshooting after I get the car back back
(hopefully end of day)?
Greg
=~=~=~=~=~=~=~=~=~=~=~= PuTTY log 2019.12.10 18:57:40 =~=~=~=~=~=~=~=~=~=~=~=
OVMS# module reset
Resetting system...
OVMS#
[K[0;32mI (228844) boot: Shutting down for restart...[0m
[0;32mI (228854) esp32wifi: Powering down WIFI driver[0m
[0;32mI (228854) sdcard: Unmounting SDCARD for reset[0m
[0;32mI (228854) sdcard: unmount done[0m
OVMS# [K
[K[0;32mI (232834) boot: Restart now[0m
OVMS# [Kets Jun 8 2016 00:22:57
rst:0xc (SW_CPU_RESET),boot:0x3b (SPI_FAST_FLASH_BOOT)
configsip: 0, SPIWP:0xee
mode:DIO, clock div:2
load:0x3fff0018,len:4
load:0x3fff001c,len:4796
load:0x40078000,len:0
load:0x40078000,len:14896
entry 0x40078d74
[0;32mI (895) psram: This chip is ESP32-D0WD[0m
[0;32mI (896) spiram: Found 32MBit SPI RAM device[0m
[0;32mI (896) spiram: SPI RAM mode: flash 40m sram 40m[0m
[0;32mI (899) spiram: PSRAM initialized, cache is in low/high (2-core) mode.[0m
[0;32mI (906) cpu_start: Pro cpu up.[0m
[0;32mI (910) cpu_start: Application information:[0m
[0;32mI (915) cpu_start: Project name: ovms3[0m
[0;32mI (919) cpu_start: App version: 3.2.007[0m
[0;32mI (924) cpu_start: Compile time: Dec 9 2019 20:19:55[0m
[0;32mI (930) cpu_start: ELF file SHA256: 14822bd8e0d2c843...[0m
[0;32mI (936) cpu_start: ESP-IDF: v3.3-beta3-772-gc3465e0[0m
[0;32mI (943) cpu_start: Starting app cpu, entry point is 0x40081668[0m
[0;32mI (935) cpu_start: App cpu up.[0m
[0;32mI (1828) spiram: SPI SRAM memory test OK[0m
[0;32mI (1828) heap_init: Initializing. RAM available for dynamic allocation:[0m
[0;32mI (1828) heap_init: At 3FFAE6E0 len 00001920 (6 KiB): DRAM[0m
[0;32mI (1835) heap_init: At 3FFBC540 len 00023AC0 (142 KiB): DRAM[0m
[0;32mI (1841) heap_init: At 3FFE0440 len 00003AE0 (14 KiB): D/IRAM[0m
[0;32mI (1847) heap_init: At 3FFE4350 len 0001BCB0 (111 KiB): D/IRAM[0m
[0;32mI (1854) heap_init: At 40099C20 len 000063E0 (24 KiB): IRAM[0m
[0;32mI (1860) cpu_start: Pro cpu start user code[0m
[0;32mI (1865) spiram: Adding pool of 4096K of external SPI memory to heap allocator[0m
[0;32mI (217) ovms_main: Set default logging level for * to INFO[0m
[0;32mI (218) ovms_main: Pre-allocated 2MB of SPIRAM at 0x3f800028 (workaround ESP32 bug)[0m
[0;32mI (221) command: Initialising COMMAND (1000)[0m
[0;32mI (227) boot: Initialising BOOT (1100)[0m
[0;32mI (230) boot: Boot #13 reasons for CPU0=12 and CPU1=12[0m
[0;32mI (236) boot: Reset reason Exception/panic (4)[0m
[0;32mI (241) boot: Soft reset by user[0m
[0;32mI (245) events: Initialising EVENTS (1200)[0m
[0;32mI (250) config: Initialising CONFIG (1400)[0m
[0;32mI (255) time: Initialising TIME (1500)[0m
[0;32mI (260) script: Initialising SCRIPTS (1600)[0m
[0;32mI (264) script: Using DUKTAPE javascript engine[0m
[0;32mI (270) metrics: Initialising METRICS (1810)[0m
[0;32mI (274) metrics: Expanding DUKTAPE javascript engine[0m
[0;32mI (285) notify: Initialising NOTIFICATIONS (1820)[0m
[0;32mI (286) notify: Registered notification type info[0m
[0;32mI (291) notify: Registered notification type error[0m
[0;32mI (296) notify: Registered notification type alert[0m
[0;32mI (302) notify: Registered notification type data[0m
[0;32mI (307) notify: Registered notification type stream[0m
[0;32mI (312) notify: Expanding DUKTAPE javascript engine[0m
[0;32mI (318) location: Initialising LOCATIONS (1900)[0m
[0;32mI (325) location: Expanding DUKTAPE javascript engine[0m
[0;32mI (329) vehicle: Initialising VEHICLE Factory (2000)[0m
[0;32mI (336) pcp: Initialising POWER (4000)[0m
[0;32mI (339) max7317: Initialising MAX7317 EGPIO (4200)[0m
[0;32mI (345) sdcard: Initialising SD CARD (4400)[0m
[0;32mI (350) ota: Initialising OTA (4400)[0m
[0;32mI (354) canformat: Initialising CAN Format Factory (4500)[0m
[0;32mI (360) canformat-crtd: Registering CAN Format: CRTD (4505)[0m
[0;32mI (366) canformat-pcap: Registering CAN Format: PCAP (4505)[0m
[0;32mI (372) canformat-gvret: Registering CAN Format: GVRET (4505)[0m
[0;32mI (379) canformat-lawricel: Registering CAN Format: LAWRICEL (4505)[0m
[0;32mI (386) canformat-raw: Registering CAN Format: RAW (4505)[0m
[0;32mI (392) can: Initialising CAN (4510)[0m
[0;32mI (398) dbc-app: Initialising DBC (4520)[0m
[0;32mI (402) canlog: Initialising CAN logging (4550)[0m
[0;32mI (406) canlog-tcpserver: Initialising CAN logging as TCP server (4560)[0m
[0;32mI (414) canlog-vfs: Initialising CAN logging to VFS (4560)[0m
[0;32mI (419) canlog-monitor: Initialising CAN logging to MONITOR (4560)[0m
[0;32mI (426) canlog-tcpclient: Initialising CAN logging as TCP client (4560)[0m
[0;32mI (434) canplay: Initialising CAN play framework (4570)[0m
[0;32mI (439) canplay-vfs: Initialising CAN playing from VFS (4580)[0m
[0;32mI (446) simcom: Initialising SIMCOM (4600)[0m
[0;32mI (451) test: Initialising TEST (5000)[0m
[0;32mI (455) module: Initialising MODULE (5100)[0m
[0;32mI (460) vfs: Initialising VFS (5200)[0m
[0;32mI (464) ovms-server: Initialising OVMS Server (6000)[0m
[0;32mI (469) ovms-server-v2: Initialising OVMS V2 Server (6100)[0m
[0;32mI (476) ovms-server-v3: Initialising OVMS V3 Server (6200)[0m
[0;32mI (482) obd2ecu: Initialising OBD2ECU (7000)[0m
[0;32mI (487) canopen: Initialising CANopen (7000)[0m
[0;32mI (493) esp32wifi: Initialising ESP32WIFI (8000)[0m
[0;32mI (497) ovms-mdns: Initialising MDNS (8100)[0m
[0;32mI (502) webserver: Initialising WEBSERVER (8200)[0m
[0;32mI (510) ssh: Initialising SSH (8300)[0m
[0;32mI (512) powermgmt: Initialising POWERMGMT (8500)[0m
[0;32mI (517) re: Initialising RE Tools (8800)[0m
[0;32mI (522) pushover: Initialising Pushover client (8800)[0m
[0;32mI (528) netmanager: Initialising NETMANAGER (8999)[0m
[0;32mI (536) v-zeva: Registering Vehicle: ZEVA (9000)[0m
[0;32mI (538) v-voltampera: Registering Vehicle: Volt/Ampera (9000)[0m
[0;32mI (544) v-track: Registering Vehicle: TRACK (9000)[0m
[0;32mI (550) v-thinkcity: Registering Vehicle: THINK CITY (9000)[0m
[0;32mI (556) v-teslaroadster: Registering Vehicle: Tesla Roadster (9000)[0m
[0;32mI (563) v-teslamodels: Registering Vehicle: Tesla Model S (9000)[0m
[0;32mI (570) v-teslamodel3: Registering Vehicle: Tesla Model 3 (9000)[0m
[0;32mI (576) v-smarteq: Registering Vehicle: SMART EQ (9000)[0m
[0;32mI (582) v-smarted: Registering Vehicle: SMART ED (9000)[0m
[0;32mI (588) v-zoe: Registering Vehicle: Renault Zoe (9000)[0m
[0;32mI (594) v-twizy: Registering Vehicle: Renault Twizy (9000)[0m
[0;32mI (600) v-obdii: Registering Vehicle: OBDII (9000)[0m
[0;32mI (606) v-none: Registering Vehicle: NONE (9000)[0m
[0;32mI (611) v-nissanleaf: Registering Vehicle: Nissan Leaf (9000)[0m
[0;32mI (617) v-mitsubishi: Registering Vehicle: Mitsubishi iMiEV, Citroen C-Zero, Peugeot iOn (9000)[0m
[0;32mI (627) v-kiasoulev: Registering Vehicle: Kia Soul EV (9000)[0m
[0;32mI (633) v-kianiroev: Registering Vehicle: Kia Niro / Hyundai Kona EV (9000)[0m
[0;32mI (641) v-fiat500e: Registering Vehicle: FIAT 500e (9000)[0m
[0;32mI (647) v-demo: Registering Vehicle: DEMO (9000)[0m
[0;32mI (652) vehicle_dbc: Registering Vehicle: DBC based vehicle (9000)[0m
[0;32mI (659) version: Initialising Versioning (9900)[0m
[0;32mI (667) cpu_start: Starting scheduler on PRO CPU.[0m
[0;32mI (0) cpu_start: Starting scheduler on APP CPU.[0m
[0;32mI (0) script: Duktape: Scripting task is running[0m
[0;32mI (754) ovms_main: Executing on CPU core 0[0m
[0;32mI (754) ovms_main: Mounting CONFIG...[0m
[0;32mI (804) ovms_main: Configure logging...[0m
[0;33mW (804) webserver: UpdateGlobalAuthFile: no password set => no auth for web console[0m
[0;32mI (804) ovms_main: Registering default configs...[0m
[0;32mI (814) ovms_main: Starting HOUSEKEEPING...[0m
[0;32mI (814) housekeeping: Initialising HOUSEKEEPING Framework...[0m
[0;32mI (824) housekeeping: Executing on CPU core 1[0m
[0;32mI (824) housekeeping: reset_reason: cpu0=12, cpu1=12[0m
[0;32mI (834) housekeeping: Initialising WATCHDOG...[0m
[0;32mI (834) housekeeping: Starting PERIPHERALS...[0m
[0;32mI (844) peripherals: Initialising OVMS Peripherals...[0m
[0;32mI (844) peripherals: TCP/IP Adaptor[0m
[0;32mI (854) peripherals: ESP32 system[0m
[0;32mI (854) peripherals: SPI bus[0m
[0;32mI (864) peripherals: MAX7317 I/O Expander[0m
[0;32mI (864) peripherals: ESP32 CAN[0m
[0;32mI (874) peripherals: ESP32 WIFI[0m
[0;32mI (874) peripherals: ESP32 ADC[0m
[0;32mI (874) peripherals: MCP2515 CAN 1/2[0m
[0;32mI (884) mcp2515: can2: SetPowerMode off[0m
[0;32mI (964) peripherals: MCP2515 CAN 2/2[0m
[0;32mI (964) mcp2515: can3: SetPowerMode off[0m
[0;32mI (1044) peripherals: SD CARD[0m
[0;32mI (1044) peripherals: SIMCOM MODEM[0m
[0;32mI (1044) gpio: GPIO[13]| InputEn: 0| OutputEn: 1| OpenDrain: 0| Pullup: 1| Pulldown: 0| Intr:0 [0m
[0;32mI (1054) gpio: GPIO[4]| InputEn: 1| OutputEn: 0| OpenDrain: 0| Pullup: 1| Pulldown: 0| Intr:0 [0m
[0;32mI (1064) uart: queue free spaces: 50[0m
[0;32mI (1064) ext12v: Powering off external 12V devices[0m
[0;32mI (1074) housekeeping: Auto init max7317 (free: 193708 bytes)[0m
[0;32mI (1074) housekeeping: Auto init ext12v (free: 193708 bytes)[0m
[0;32mI (1084) ext12v: Powering on external 12V devices[0m
[0;32mI (1084) housekeeping: Auto init dbc (free: 193708 bytes)[0m
[0;32mI (1094) housekeeping: Auto init wifi (free: 193708 bytes)[0m
[0;32mI (1104) esp32wifi: Powering up WIFI driver[0m
I (1134) wifi: wifi driver task: 3ffd192c, prio:23, stack:3584, core=0
[0;32mI (1134) system_api: Base MAC address is not set, read default base MAC address from BLK0 of EFUSE[0m
[0;32mI (1144) system_api: Base MAC address is not set, read default base MAC address from BLK0 of EFUSE[0m
I (1164) wifi: wifi firmware version: aeed694
I (1164) wifi: config NVS flash: enabled
I (1164) wifi: config nano formating: disabled
I (1164) wifi: Init dynamic tx buffer num: 16
I (1174) wifi: Init data frame dynamic rx buffer num: 16
I (1174) wifi: Init management frame dynamic rx buffer num: 16
I (1184) wifi: Init management short buffer num: 32
I (1184) wifi: Init static rx buffer size: 2212
I (1194) wifi: Init static rx buffer num: 16OVMS Developers <ovmsdev at lists.teslaclub.hk>
I (1194) wifi: Init dynamic rx buffer num: 16
[0;32mI (1974) phy: phy_version: 4102, 2fa7a43, Jul 15 2019, 13:06:06, 0, 0[0m
I (1974) wifi: mode : sta (30:ae:a4:43:92:88) + softAP (30:ae:a4:43:92:89)
I (1974) wifi: Total power save buffer number: 8
I (1984) wifi: Init max length of beacon: 752/752
[0;32mI (1994) housekeeping: Auto init modem (free: 148328 bytes)[0m
[0;32mI (1994) simcom: State: Enter PoweringOn state[0m
[0;32mI (2004) simcom: Power Cycle[0m
[0;32mI (3004) housekeeping: Auto init vehicle (free: 147532 bytes)[0m
[0;32mI (3004) v-teslaroadster: Tesla Roadster v1.x, v2.x and v3.0 vehicle module[0m
[0;32mI (3014) housekeeping: Auto init obd2ecu (free: 139360 bytes)[0m
[0;32mI (3114) mcp2515: can3: SetPowerMode on[0m
[0;32mI (3214) housekeeping: Auto init server v2 (free: 132140 bytes)[0m
[0;32mI (3214) ovms-server-v2: OVMS Server V2 registered metric modifier is #1[0m
[0;32mI (3224) ovms-server-v2: Status: Server has been started[0m
[0;32mI (3224) ovms-server-v2: OVMS Server v2 running[0m
[0;32mI (3234) housekeeping: Auto init server v3 (free: 132032 bytes)[0m
[0;32mI (3234) housekeeping: Auto init javascript (free: 132032 bytes)[0m
[0;32mI (3244) housekeeping: Auto init done (free: 132032 bytes)[0m
[0;31mE (3244) can: can1: intr=7 rxpkt=6 txpkt=0 errflags=0x80c00 rxerr=0 txerr=0 rxovr=0 txovr=0 txdelay=0 wdgreset=0 errreset=0[0m
[0;32mI (3254) housekeeping: Starting USB console...[0m
[0;32mI (3264) uart: queue free spaces: 100[0m
Firmware: 3.2.007/ota_1/main
Hardware: OVMS WIFI BLE BT cores=2 rev=ESP32/1
OVMS# [0;32mI (3254) script: Duktape: Creating heap[0m
[K[0;32mI (3294) script: Duktape: Initialising module system[0m
[0;31mE (3474) events: SignalEvent: queue overflow, event 'vehicle.charge.state' dropped[0m
[0;31mE (3474) events: SignalEvent: queue overflow, event 'vehicle.charge.mode' dropped[0m
[0;32mI (3644) netmanager: WIFI access point is up[0m
[0;32mI (3644) esp32wifi: AP started with SSID: OVMS, MAC: 30:ae:a4:43:92:89, IP: 192.168.4.1[0m
[0;32mI (3734) ovms-mdns: Starting MDNS[0m
[0;32mI (3784) webserver: Launching Web Server[0m
[0;32mI (3784) ssh: Launching SSH Server[0m
OVMS# [K
[KI (4434) wifi: ap channel adjust o:1,1 n:6,2
I (4434) wifi: new:<6,0>, old:<1,0>, ap:<6,2>, sta:<6,0>, prof:1
OVMS# [K
[KI (5124) wifi: state: init -> auth (b0)
I (5124) wifi: state: auth -> assoc (0)
I (5134) wifi: state: assoc -> run (10)
I (5154) wifi: connected with gregnet, channel 6, HT20, bssid = 40:b0:76:32:ea:70
I (5154) wifi: pm start, type: 1
[0;32mI (5164) esp32wifi: STA connected with SSID: gregnet, BSSID: 40:b0:76:32:ea:70, Channel: 6, Auth: WPA2[0m
[0;32mI (5174) event: sta ip: 10.30.1.105, mask: 255.255.255.0, gw: 10.30.1.1[0m
[0;32mI (5184) netmanager: WIFI client got IP[0m
[0;32mI (5184) esp32wifi: STA got IP with SSID 'gregnet' AP 40:b0:76:32:ea:70: MAC: 30:ae:a4:43:92:88, IP: 10.30.1.105, mask: 255.255.255.0, gw: 10.30.1.1[0m
OVMS# [K
[K[0;32mI (5834) sdcard: SD CARD has been inserted[0m
[0;32mI (5924) sdcard: mount done[0m
OVMS# [K
[K[0;32mI (6834) netmanager: WIFI client has good signal quality (-86.6 dBm); connect[0m
[0;32mI (6844) netmanager: Interface priority is st1 (10.30.1.105/255.255.255.0 gateway 10.30.1.1)[0m
[0;32mI (6844) netmanager: Set DNS#0 9.9.9.9[0m
[0;32mI (6844) netmanager: Set DNS#1 8.8.8.8[0m
[0;32mI (6844) netmanager: WIFI client up (with MODEM down): starting network with WIFI client[0m
[0;32mI (6874) time: Starting SNTP client[0m
[0;32mI (6884) ovms-server-v2: Status: Network is up, so attempt network connection[0m
OVMS# [KGuru Meditation Error: Core 0 panic'ed (LoadProhibited). Exception was unhandled.
Core 0 register dump:
PC : 0x400d5e4c PS : 0x00060030 A0 : 0x00000000 A1 : 0x3ffc5c40
A2 : 0x3ffb3eec A3 : 0x400d5e46 A4 : 0x00000000 A5 : 0x00000000
A6 : 0x00000000 A7 : 0x00000000 A8 : 0x3f400928 A9 : 0x3ffc5c00
A10 : 0x00000000 A11 : 0x3ffc5c48 A12 : 0x00000001 A13 : 0x00000000
A14 : 0x3ffc4bec A15 : 0x00000000 SAR : 0x00000003 EXCCAUSE: 0x0000001c
EXCVADDR: 0x00000000 LBEG : 0x4008f33c LEND : 0x4008f36a LCOUNT : 0x00000000
ELF file SHA256: 14822bd8e0d2c843b0e5641a469ba2e865a09b94726cb281c70dbbe7bffe8a88
Backtrace: 0x400d5e4c:0x3ffc5c40 0x7ffffffd:0x3ffc5c90
Rebooting...
entry 0x40078d74
[0;32mI (914) cpu_start: Project name: ovms3[0m
[0;32mI (1827) spiram: SPI SRAM memory test OK[0m
[0;32mI (230) boot: Boot #14 reasons for CPU0=12 and CPU1=12[0m
[0;31mE (241) boot: Early crash #1 detected[0m
[0;32mI (246) events: Initialising EVENTS (1200)[0m
[0;32mI (251) config: Initialising CONFIG (1400)[0m
[0;32mI (256) time: Initialising TIME (1500)[0m
[0;32mI (275) metrics: Expanding DUKTAPE javascript engine[0m
[0;32mI (313) notify: Expanding DUKTAPE javascript engine[0m
[0;32mI (340) max7317: Initialising MAX7317 EGPIO (4200)[0m
[0;32mI (355) canformat: Initialising CAN Format Factory (4500)[0m
[0;32mI (373) canformat-gvret: Registering CAN Format: GVRET (4505)[0m
[0;32mI (399) dbc-app: Initialising DBC (4520)[0m
[0;32mI (415) canlog-vfs: Initialising CAN logging to VFS (4560)[0m
[0;32mI (420) canlog-monitor: Initialising CAN logging to MONITOR (4560)[0m
[0;32mI (427) canlog-tcpclient: Initialising CAN logging as TCP client (4560)[0m
[0;32mI (435) canplay: Initialising CAN play framework (4570)[0m
[0;32mI (440) canplay-vfs: Initialising CAN playing from VFS (4580)[0m
[0;32mI (452) test: Initialising TEST (5000)[0m
[0;32mI (456) module: Initialising MODULE (5100)[0m
[0;32mI (461) vfs: Initialising VFS (5200)[0m
[0;32mI (465) ovms-server: Initialising OVMS Server (6000)[0m
[0;32mI (470) ovms-server-v2: Initialising OVMS V2 Server (6100)[0m
[0;32mI (483) obd2ecu: Initialising OBD2ECU (7000)[0m
[0;32mI (488) canopen: Initialising CANopen (7000)[0m
[0;32mI (494) esp32wifi: Initialising ESP32WIFI (8000)[0m
[0;32mI (498) ovms-mdns: Initialising MDNS (8100)[0m
[0;32mI (503) webserver: Initialising WEBSERVER (8200)[0m
[0;32mI (518) re: Initialising RE Tools (8800)[0m
[0;32mI (523) pushover: Initialising Pushover client (8800)[0m
[0;32mI (545) v-track: Registering Vehicle: TRACK (9000)[0m
[0;32mI (577) v-smarteq: Registering Vehicle: SMART EQ (9000)[0m
[0;32mI (583) v-smarted: Registering Vehicle: SMART ED (9000)[0m
[0;32mI (618) v-mitsubishi: Registering Vehicle: Mitsubishi iMiEV, Citroen C-Zero, Peugeot iOn (9000)[0m
[0;32mI (668) cpu_start: Starting scheduler on PRO CPU.[0m
[0;32mI (2804) simcom: State: Enter PoweredOn state[0m
[0;32mI (3214) ovms-server-v2: Status: Server has been started[0m
[0;32mI (3254) housekGuru Meditation Error: Core 0 panic'ed (LoadProhibited). Exception was unhandled.
PC : 0x400d5e4c PS : 0x00060d30 A0 : 0x00000000 A1 : 0x3ffc5c40
A14 : 0x3ffc498c A15 : 0x00000000 SAR : 0x00000003 EXCCAUSE: 0x0000001c
Rebooting...
etc...
