    Tue Apr  2 08:53:13 HKT 2019
Steve,
> What should I look for when this false alarm occurs?  Is it likely
> that the alarm is issued when stable GPS operation is restored, so
> what I really would need to see is a log of conditions before the
> alarm?
What we would ideally need would be at the time of the issue:
metric list v.p
CAN bus dump (can1) ID #100, B1=0x83,0x84,0x85
I appreciate that is hard. Perhaps just leave a CAN bus dump running over wifi throughout the event? You could leave that running for hours. We could then replay that back through a box to recreate the issue.
> And now that I have issued some messages in the app, how do I switch
> back to other functions?  Is there a way to make the keyboard drop and
> then find the buttons at the bottom of the screen?  (I realize that
> restarting the app would be a solution.)
Just click on the screen, away from the keyboard.
> On 2 Apr 2019, at 5:47 AM, Stephen Casner <casner at acm.org> wrote:
> Mark,
> The false alarm occured again a few minutes ago.  I wanted to use the
> web shell UI to check some status, but using the new messages feature
> of the iPhone app I found the wifi was wedged again.  After I turned
> wifi off and then back to client mode I would log in from the web
> again.  I issued a location status command that indicated good lock.
> alarm?
> On Mon, 1 Apr 2019, Mark Webb-Johnson wrote:
>> I don't see this on the Model S vehicle.
>> I suspect the issue is not handling GPS lock indicator correctly in the vehicle modules. For the roadster, we use ID#100, B1=0x85 (GPS direction and altitude), B2==1 to control this, but that was always a 'best guess' without much data to back it up.
>>> On 31 Mar 2019, at 11:12 PM, Stephen Casner <casner at acm.org> wrote:
>>> Mark,
>>> This message reminds me to mention that both Timothy Rodgers and I
>>> have received false alarm car-theft notifications from OVMS.  Have
>>> you?  I presume these are caused by temporary inaccuracy in the GPS
>>> signal.
>>>                                                       -- Steve
>>> On Sun, 31 Mar 2019, Mark Webb-Johnson wrote:
>>>> Except it does use the metric that says the car is on (for the car theft feature).
>>>>> On 31 Mar 2019, at 9:37 PM, Mark Webb-Johnson <mark at webb-johnson.net> wrote:
>>>>> Location service just works off gps data. For cars using the gps in the simcom modules, that shouldn't rely on can at all.
>>>>> Regards, Mark
>>>>>> On 29 Mar 2019, at 3:56 PM, ovms <ovms at topphemmelig.no> wrote:
>>>>>> Hi
>>>>>> I would like to run scripts based on location. The scripts work fine, but the location service stops working.
>>>>>> I guess the location service requires CAN1 to be working?
>>>>>> Since CAN1 stops receiving after a short period of time, the location service also stops.
>>>>>> Is there a way to bypass this so the location service does not depend on CAN1 working?
>>>>>> Kind regards,
>>>>>> Stein Arne Sordal
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20190402/2c78ac85/attachment.htm>
