    Stephen Casner
    casner at acm.org
    Tue Apr  2 05:47:54 HKT 2019
Mark,
The false alarm occured again a few minutes ago.  I wanted to use the
web shell UI to check some status, but using the new messages feature
of the iPhone app I found the wifi was wedged again.  After I turned
wifi off and then back to client mode I would log in from the web
again.  I issued a location status command that indicated good lock.
What should I look for when this false alarm occurs?  Is it likely
that the alarm is issued when stable GPS operation is restored, so
what I really would need to see is a log of conditions before the
alarm?
And now that I have issued some messages in the app, how do I switch
back to other functions?  Is there a way to make the keyboard drop and
then find the buttons at the bottom of the screen?  (I realize that
restarting the app would be a solution.)
On Mon, 1 Apr 2019, Mark Webb-Johnson wrote:
> I don't see this on the Model S vehicle.
> I suspect the issue is not handling GPS lock indicator correctly in the vehicle modules. For the roadster, we use ID#100, B1=0x85 (GPS direction and altitude), B2==1 to control this, but that was always a 'best guess' without much data to back it up.
> > On 31 Mar 2019, at 11:12 PM, Stephen Casner <casner at acm.org> wrote:
> > Mark,
> > This message reminds me to mention that both Timothy Rodgers and I
> > have received false alarm car-theft notifications from OVMS.  Have
> > you?  I presume these are caused by temporary inaccuracy in the GPS
> > signal.
> >                                                        -- Steve
> > On Sun, 31 Mar 2019, Mark Webb-Johnson wrote:
> >> Except it does use the metric that says the car is on (for the car theft feature).
> >>> On 31 Mar 2019, at 9:37 PM, Mark Webb-Johnson <mark at webb-johnson.net> wrote:
> >>> Location service just works off gps data. For cars using the gps in the simcom modules, that shouldn't rely on can at all.
> >>> Regards, Mark
> >>>> On 29 Mar 2019, at 3:56 PM, ovms <ovms at topphemmelig.no> wrote:
> >>>> Hi
> >>>> I would like to run scripts based on location. The scripts work fine, but the location service stops working.
> >>>> I guess the location service requires CAN1 to be working?
> >>>> Since CAN1 stops receiving after a short period of time, the location service also stops.
> >>>> Is there a way to bypass this so the location service does not depend on CAN1 working?
> >>>> Kind regards,
> >>>> Stein Arne Sordal
> > OvmsDev mailing list
