[Ovmsdev] Can buses stop after some time
    ovms
    ovms at topphemmelig.no
    Mon Apr  1 15:49:11 HKT 2019
Looks the same, see attachment.
-Stein Arne-
On 2019-04-01 09:38, Mark Webb-Johnson <mark at webb-johnson.net> wrote:
> This is the thread from last summer talking about CAN bus lock-ups.
> I’m guessing this is still happening for Leaf? Since the changes made below (back then), I haven’t seen it in my car.
> Next time this happens to you guys (can2 stopped), can you get a ‘can can2 status’, wait 30 seconds, and repeat. Then send it here for us to look at.
> > On 7 Jul 2018, at 10:37 PM, Mark Webb-Johnson <mark at webb-johnson.net(mailto:mark at webb-johnson.net)> wrote:
> > I’m trying to recreate this with my three-can-buses-connected DB9 plugged in. Transmitting on CAN1 should make it appear on CAN2 and CAN3.
> > Here is what I see:
> > > OVMS# can can1 start active 1000000
> > > Can bus can1 started in mode active at speed 1000000bps
> > > OVMS# can can2 start active 1000000
> > > Can bus can2 started in mode active at speed 1000000bps
> > > OVMS# test cantx can1 25000
> > > Testing 25000 frames on can1
> > > Transmitted 25000 frames in 6.466209s = 258us/frame
> > > OVMS# can can1 status
> > > CAN: can1
> > > Mode: Active
> > > Speed: 1000000
> > > Interrupts: 24771
> > > Rx pkt: 0
> > > Rx err: 0
> > > Rx ovrflw: 0
> > > Tx pkt: 24880
> > > Tx delays: 24703
> > > Tx err: 0
> > > Tx ovrflw: 109
> > > Err flags: 0
> > > OVMS# can can2 status
> > > CAN: can2
> > > Mode: Active
> > > Speed: 1000000
> > > Interrupts: 19084
> > > Rx pkt: 24770
> > > Rx err: 0
> > > Rx ovrflw: 1
> > > Tx pkt: 0
> > > Tx delays: 0
> > > Tx err: 0
> > > Tx ovrflw: 0
> > > Err flags: 0x2040
> > Note the err flags 0x2040 on CAN2, but the bus remains up and working fine.
> > Repeating the test gives us:
> > > Transmitted 25000 frames in 6.479670s = 259us/frame
> > > CAN: can1
> > > Mode: Active
> > > Speed: 1000000
> > > Interrupts: 49546
> > > Rx pkt: 0
> > > Rx err: 0
> > > Rx ovrflw: 0
> > > Tx pkt: 49771
> > > Tx delays: 49417
> > > Tx err: 0
> > > Tx ovrflw: 207
> > > Err flags: 0
> > > CAN: can2
> > > Mode: Active
> > > Speed: 1000000
> > > Interrupts: 38288
> > > Rx pkt: 49545
> > > Rx err: 0
> > > Rx ovrflw: 3
> > > Tx pkt: 0
> > > Tx delays: 0
> > > Tx err: 0
> > > Tx ovrflw: 0
> > > Err flags: 0x2040
> > Looking at the mcp2515 code, it seems that Err flags are only stored "if (intstat & 0b10100000)”. That is "ERRF 0x80 = message tx/rx error” or "ERRIF 0x20 = overflow / error state change”. It is also set to "(intstat & 0b10100000) << 8 | errflag”, so doesn’t show all the error statuses. It is hard to rely on that for other errors/status on lock-up. Given that error_flags is a uint32_t, I think we can store more in it to allow for better diagnosis.
> > I changed the mcp2515 driver to always set error_flags, on each interrupt handled (except spurious interrupts with no flags found), as follows:
> > > SSSSSSSSFFFFFFFF***EB01TLLLLLLLL
> > > SSSSSSSS = intstat
> > > FFFFFFFF = errflag
> > > B = RXB0 or RXB1 overflow flags cleared
> > > 0 = RXB0 overflowed
> > > 1 = RXB1 overflowed
> > > T = TX buffer has become available
> > > E = Error/WakeUp flags were cleared
> > > LLLLLLLL = intflag
> > I did find a problem on line 300: if (intstat & 0b10100000). It think that should be 0b11100000 (to also pickup the RXB0 overflow), and removed the m_status.rxbuf_overflow++ from RXB0 overflow (as it is not really an overflow - as RXB1 got the data).
> > With those changes made, I get:
> > > Transmitted 25000 frames in 6.389849s = 255us/frame
> > > CAN: can1
> > > Mode: Active
> > > Speed: 1000000
> > > Interrupts: 24777
> > > Rx pkt: 0
> > > Rx err: 0
> > > Rx ovrflw: 0
> > > Tx pkt: 24884
> > > Tx delays: 24739
> > > Tx err: 0
> > > Tx ovrflw: 116
> > > Err flags: 0x00000000
> > > CAN: can2
> > > Mode: Active
> > > Speed: 1000000
> > > Interrupts: 18935
> > > Rx pkt: 24777
> > > Rx err: 0
> > > Rx ovrflw: 0
> > > Tx pkt: 0
> > > Tx delays: 0
> > > Tx err: 0
> > > Tx ovrflw: 0
> > > Err flags: 0x01000001
> > I don’t think I’ve fixed anything (apart from that minor issue with RXB0 overflow diagnostics), but hopefully the new error_flags display should help finding out what is causing this lockup. Hopefully I haven’t broken anything.
> > Regards, Mark.
> > > On 7 Jul 2018, at 10:42 AM, Tom Parker <tom at carrott.org(mailto:tom at carrott.org)> wrote:
> > > On 07/07/18 00:05, Mark Webb-Johnson wrote:
> > > > Err flags 0x2040. The 0x20 part is the error interrupt. The 0x40 part is "RX0OVR: Receive Buffer 0 Overflow Flag bit”.
> > > > Where the number on ‘can can2 status’ moving at all? Or completely stuck?
> > > None of the can can2 status numbers change when the can bus is broken. After power cycling it they move.
> > > > Seems different than the fault Greg and I are seeing. This one likely to be interrupt flag, or buffer overflow, not being cleared correctly. I’m guessing the overflow because that just doesn’t seem correct in mcp2515::RxCallback(). I’ll focus on that and have a look.
> > > I just checked the car again and it stopped with Rx ovrflw number only 1281, half what it got to last time.
> > > _______________________________________________
> > > OvmsDev mailing list
> > > OvmsDev at lists.openvehicles.com(mailto:OvmsDev at lists.openvehicles.com)
> > > http://lists.openvehicles.com/mailman/listinfo/ovmsdev _______________________________________________
> > http://lists.openvehicles.com/mailman/listinfo/ovmsdev _______________________________________________ OvmsDev mailing list OvmsDev at lists.openvehicles.com http://lists.openvehicles.com/mailman/listinfo/ovmsdev
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20190401/971249d3/attachment.htm>
Type: image/png
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20190401/971249d3/attachment-0004.png>
Type: image/png
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20190401/971249d3/attachment-0005.png>
