[Ovmsdev] Can buses stop after some time
    Mon Apr  1 15:38:16 HKT 2019
This is the thread from last summer talking about CAN bus lock-ups.
I’m guessing this is still happening for Leaf? Since the changes made below (back then), I haven’t seen it in my car.
Next time this happens to you guys (can2 stopped), can you get a ‘can can2 status’, wait 30 seconds, and repeat. Then send it here for us to look at.
> On 7 Jul 2018, at 10:37 PM, Mark Webb-Johnson <mark at webb-johnson.net> wrote:
> I’m trying to recreate this with my three-can-buses-connected DB9 plugged in. Transmitting on CAN1 should make it appear on CAN2 and CAN3.
> Here is what I see:
> OVMS# can can1 start active 1000000
> Can bus can1 started in mode active at speed 1000000bps
> OVMS# can can2 start active 1000000
> Can bus can2 started in mode active at speed 1000000bps
> OVMS# test cantx can1 25000
> Testing 25000 frames on can1
> Transmitted 25000 frames in 6.466209s = 258us/frame
> OVMS# can can1 status
> CAN:       can1
> Mode:      Active
> Speed:     1000000
> Interrupts:               24771
> Rx pkt:                       0
> Rx err:                       0
> Rx ovrflw:                    0
> Tx pkt:                   24880
> Tx delays:                24703
> Tx err:                       0
> Tx ovrflw:                  109
> Err flags: 0
> OVMS# can can2 status
> CAN:       can2
> Mode:      Active
> Speed:     1000000
> Interrupts:               19084
> Rx pkt:                   24770
> Rx err:                       0
> Rx ovrflw:                    1
> Tx pkt:                       0
> Tx delays:                    0
> Tx err:                       0
> Tx ovrflw:                    0
> Err flags: 0x2040
> Note the err flags 0x2040 on CAN2, but the bus remains up and working fine.
> Repeating the test gives us:
> Transmitted 25000 frames in 6.479670s = 259us/frame
> CAN:       can1
> Mode:      Active
> Speed:     1000000
> Interrupts:               49546
> Rx pkt:                       0
> Rx err:                       0
> Rx ovrflw:                    0
> Tx pkt:                   49771
> Tx delays:                49417
> Tx err:                       0
> Tx ovrflw:                  207
> Err flags: 0
> CAN:       can2
> Mode:      Active
> Speed:     1000000
> Interrupts:               38288
> Rx pkt:                   49545
> Rx err:                       0
> Rx ovrflw:                    3
> Tx pkt:                       0
> Tx delays:                    0
> Tx err:                       0
> Tx ovrflw:                    0
> Err flags: 0x2040
> Looking at the mcp2515 code, it seems that Err flags are only stored "if (intstat & 0b10100000)”. That is "ERRF 0x80 = message tx/rx error” or "ERRIF 0x20 = overflow / error state change”. It is also set to "(intstat & 0b10100000) << 8 | errflag”, so doesn’t show all the error statuses. It is hard to rely on that for other errors/status on lock-up. Given that error_flags is a uint32_t, I think we can store more in it to allow for better diagnosis.
> I changed the mcp2515 driver to always set error_flags, on each interrupt handled (except spurious interrupts with no flags found), as follows:
> SSSSSSSSFFFFFFFF***EB01TLLLLLLLL
> SSSSSSSS = intstat
> FFFFFFFF = errflag
> B = RXB0 or RXB1 overflow flags cleared
> 0 = RXB0 overflowed
> 1 = RXB1 overflowed
> T = TX buffer has become available
> E = Error/WakeUp flags were cleared
> LLLLLLLL = intflag
> I did find a problem on line 300: if (intstat & 0b10100000). It think that should be 0b11100000 (to also pickup the RXB0 overflow), and removed the m_status.rxbuf_overflow++ from RXB0 overflow (as it is not really an overflow - as RXB1 got the data).
> With those changes made, I get:
> Transmitted 25000 frames in 6.389849s = 255us/frame
> CAN:       can1
> Mode:      Active
> Speed:     1000000
> Interrupts:               24777
> Rx pkt:                       0
> Rx err:                       0
> Rx ovrflw:                    0
> Tx pkt:                   24884
> Tx delays:                24739
> Tx err:                       0
> Tx ovrflw:                  116
> Err flags: 0x00000000
> CAN:       can2
> Mode:      Active
> Speed:     1000000
> Interrupts:               18935
> Rx pkt:                   24777
> Rx err:                       0
> Rx ovrflw:                    0
> Tx pkt:                       0
> Tx delays:                    0
> Tx err:                       0
> Tx ovrflw:                    0
> Err flags: 0x01000001
> I don’t think I’ve fixed anything (apart from that minor issue with RXB0 overflow diagnostics), but hopefully the new error_flags display should help finding out what is causing this lockup. Hopefully I haven’t broken anything.
>> On 7 Jul 2018, at 10:42 AM, Tom Parker <tom at carrott.org <mailto:tom at carrott.org>> wrote:
>> On 07/07/18 00:05, Mark Webb-Johnson wrote:
>>> Err flags 0x2040. The 0x20 part is the error interrupt. The 0x40 part is "RX0OVR: Receive Buffer 0 Overflow Flag bit”.
>>> Where the number on ‘can can2 status’ moving at all? Or completely stuck?
>> None of the can can2 status numbers change when the can bus is broken. After power cycling it they move.
>>> Seems different than the fault Greg and I are seeing. This one likely to be interrupt flag, or buffer overflow, not being cleared correctly. I’m guessing the overflow because that just doesn’t seem correct in mcp2515::RxCallback(). I’ll focus on that and have a look.
>> I just checked the car again and it stopped with Rx ovrflw number only 1281, half what it got to last time.
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20190401/fb78438f/attachment-0001.html>
