[Ovmsdev] Fwd: [ovms:2137] Limit speed and path
    Thu Apr 18 09:14:47 HKT 2019
@michael, or other twizy experts, can you help to answer the following support ticket?
Thanks, Mark.
> bricoauto has updated the ticket 'Limit speed and path':
> https://www.openvehicles.com/node/2137#comment-5685
> State: active
> Priority: normal
> You can visit the following URL to update this ticket:
> https://www.openvehicles.com/node/2137#comment-form
> Update text:
> Dear Friend, excuse the delay.
> I attached error image, and the firmware data.
> The ovms is v 3.1. The vehicle is a Renault Twizy 80.
> I have 3 same from different years, one from 2012, another from 2015 and
> another from 2016.
> In the 3 it happens the same, I can not change the limit of speed and the
> limit of the route.
> When I try, I activate the Can script in command # 15 with the number 1, then
> I put the key in turn 2 activated and from the mobile APP I try to change the
> speed or the path, and the message is that of the attached image.
>   We are an active tourism company, and we make excursions with these
> vehicles, and we are interested in limiting the speed and the route.
> Thank you and I hope your answer.
