[Ovmsdev] Add version strings to the boot partitions on the firmware page
Wed Nov 14 20:09:46 HKT 2018
There seems to be a compilation warning:
$ make -j 4
Build version is 3.1.011-21-g5d46d82
CXX build/main/ovms_version.o
In file included from main/ovms_version.cpp:34:0:
esp/esp-idf/components/bootloader_support/include/esp_image_format.h:44:3: warning: 'esp_image_spi_freq_t' defined but not used [-Wunused-variable]
} esp_image_spi_freq_t;
I merged it, to allow further testing on ‘edge’ boxes, but it would be good if that could be cleaned up.
> On 14 Nov 2018, at 3:46 PM, Craig Leres <leres at xse.com> wrote:
> > Could you extend the ‘ota status’ command to show the same?
> It was easier than I thought so I wrapped this up tonight and created a pull request:
> https://github.com/openvehicles/Open-Vehicle-Monitoring-System-3/pull/169/files
> Appended is sample output from "ota status".
> Craig
> OVMS# ota status
> Firmware: 3.1.011-21-g482c9d3/factory/main (build idf v3.1-dev-1586-g65355d28 Nov 13 2018 23:39:54)
> Running partition: factory
> Boot partition: factory
> Factory image: 3.1.011-21-g482c9d3
> OTA_O image: 3.1.011
> OTA_1 image: 3.1.011-16-gb8dc60e
> Server Available: 3.1.011 (no update required)
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20181114/e990f6ec/attachment.htm>
