[Ovmsdev] Add version strings to the boot partitions on the firmware page
Mon Nov 12 12:04:56 HKT 2018
> I'll measure it but I suspect it's on the order of msecs. It has to read
> about 80K of flash to find the version string.
ok
> Seems like the version finder code should live in main/ovms_version.cpp?
Yep.
> Maybe add this after the "Boot partition" line?
I think the top part of the report is showing what you have, and the bottom part is what is available. Perhaps order like this:
> OVMS# ota status
>    Firmware:          3.1.011-16-gb8dc60e-dirty/factory/main (build idf
> v3.1-dev-1586-g65355d28 Nov 11 2018 16:39:30)
>    Running partition: factory
>    Boot partition:    factory
>    Factory image:     3.1.011-16-gb8dc60e-dirty
>    OTA_0 image:       3.1.011
>    OTA_1 image:       3.1.011-16-gb8dc60e
>    Server Available:  3.1.011 (no update required)
>    Sun Nov 4 01:53:00 UTC 2018 OTA release
Better?
> On 12 Nov 2018, at 11:50 AM, Craig Leres <leres at xse.com> wrote:
> On 11/11/2018 6:53 PM, Mark Webb-Johnson wrote:
>> Looks cool. Those prefix and postfix were put there for that reason, but we never got round to doing it.
>> How is performance? If acceptable, please send a pull request and we’ll get it merged (unless anyone else has any comments / suggestions)?
>> Could you extend the ‘ota status’ command to show the same?
> Currently it shows:
>    OVMS# ota status
> I'll try for a pull request next weekend.
> 		Craig
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20181112/1560a5c8/attachment.htm>
