[Ovmsdev] yacc/lex on component/dbc
Craig Leres leres at xse.com
Mon Nov 26 02:53:45 HKT 2018
On 11/25/18 4:49 AM, Mark Webb-Johnson wrote:
> Or try bison?
I already had bison installed so I changed the dbc component.mk file to
use it on FreeBSD. Here's the pull request:
https://github.com/openvehicles/Open-Vehicle-Monitoring-System-3/pull/176/files
As noted I think it would make more sense for YACC (and probably LEX) to
be defined at a higher level. I couldn't figure out where CC and friends
are defined so took the easy way out.
While I was making changes I added the YY_NO_INPUT and YY_NO_UNPUT
defines to dbc_tokeniser.l.
		Craig
