[Ovmsdev] Automatic vehicle notifications
Fri May 25 15:39:46 HKT 2018
Am 25.05.2018 um 04:25 schrieb Mark Webb-Johnson:
> Re-visiting this, we don’t seem to have done the ‘low SOC’ notification yet. Should be quite simple, so I will handle this.
OK.
> We’re also not handling the module reset correctly and issuing charge notifications when the module starts up. This is more tricky. Should we just suppress
> all notifications within the first N seconds after boot-up (to give the vehicle modules time to set things correctly). Or should we only notify if this is not
> the first time the value has been set (add a modification count to the base metric system so we can see how many times the value has been modified)?
I solved that for the Twizy by initializing to the empty state (key 0) and not setting the charge state until it actually changes.
If the reset happens during a charge, I get a new charge start notification, but that is OK as it also informs me that the charge monitoring had a reset and
could not record the full process. If that would be suppressed, I would need a dedicated "I crashed" notification.
Adding change counters just for this seems to be unnecessary overhead. Not sure if we can use external RAM for metrics.
>> On 25 Apr 2018, at 2:45 PM, Michael Balzer <dexter at expeedo.de <mailto:dexter at expeedo.de>> wrote:
>> We can also add the "sufficient SOC/range reached" notifications, the low SOC alert and the low 12V alert to the framework.
>> Porting the low 12V detection is on my list for today/tomorrow. For the sufficient SOC/range notifications, I currently still (mis-)use the topoff state,
>> which is irritating to users.
>> Notification config should include a channel selection for each, so users can choose which of them to get by SMS. May be combinable, i.e. instead of a bool,
>> use a set of ("ip", "sms")?
>> Am 25.04.2018 um 03:13 schrieb Mark Webb-Johnson:
>>> It is time to implement vehicle notifications (charge started, charge completed, charge interrupted, etc) in the vehicle modules I am supporting. It seems
>>> that this can be done in the vehicle.{h,cpp} framework in a standard manner, and work across all vehicle types. However, I guess that will break any
>>> notifications already being produced by other vehicle types.
>>> My suggestion is:
>>> 1. A config parameter ‘notifications’, with individual instances to turn on/off the notifications. Default is all enabled.
>>> 2. OvmsVehicle::MetricModified picks up metric changes and issues the standard notifications (checking ‘notifications’ parameter appropriately).
>>> * charge_mode=>charging: Notify charge started
>>> * charge_mode=>topoff: Notify charge started
>>> * charge_mode=>heating: Notify battery heating started
>>> * charge_mode=>done: Notify charge completed
>>> * charge_mode=>stopped: Notify charge interrupted
>>> * valet_mode=>on: Notify valet mode enabled
>>> * valet_mode=>off: Notify valet mode disabled
>>> * alarm=>on: Notify alarm is sounding
>>> * alarm=>off: Notify alarm is off
>>> 3. All the above should be suppressed for the initial setting of each parameter. I will have to look into metrics to see how best that should be done; one
>>> neat way is to keep a modification count (rather than the current m_defined boolean).
>>> Does that make sense? Any objections/suggestions?
>>> Regards, Mark
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20180525/2775564d/attachment.htm>
