[Ovmsdev] 3.1.006
Wed May 23 06:14:21 HKT 2018
Steve,
yes, at build time, I suppose the static IRAM preallocations from the bluetooth and wifi improvements have grown too much to fit:
/home/balzer/esp/xtensa-esp32-elf/bin/../lib/gcc/xtensa-esp32-elf/5.2.0/../../../../xtensa-esp32-elf/bin/ld:
/home/balzer/esp/Open-Vehicle-Monitoring-System-3/vehicle/OVMS.V3/build/ovms3.elf section `.iram0.text' will not fit in region `iram0_0_seg'
/home/balzer/esp/xtensa-esp32-elf/bin/../lib/gcc/xtensa-esp32-elf/5.2.0/../../../../xtensa-esp32-elf/bin/ld: region `iram0_0_seg' overflowed by 940 bytes
This is my currently running build:
balzer at leela:~/esp/Open-Vehicle-Monitoring-System-3/vehicle/OVMS.V3> ~/esp/esp-idf/tools/idf_size.py build/ovms3.map
Total sizes:
DRAM .data size: 18760 bytes
DRAM .bss size: 42440 bytes
Used static DRAM: 61200 bytes ( 54000 available, 53.1% used)
Used static IRAM: 131000 bytes ( 72 available, 99.9% used)
Flash code: 1908902 bytes
Flash rodata: 791536 bytes
Total image size:~2850198 bytes (.bin may be padded larger)
So that's also quite close already.
Am 22.05.2018 um 23:50 schrieb Stephen Casner:
> Michael,
> Can you clarify regarding the IRAM space issues. Was there an error
> at build time? If so, that's a surprise because I don't think our
> code does anything with preallocation of IRAM so that means everyone
> who uses a similar set of system functions would hit this.
> My memory diagnostic code allocates from IRAM if available, but only
> if the memory commands are issued, so any system allocations in IRAM
> should come first.
> -- Steve
> On Tue, 22 May 2018, Michael Balzer wrote:
>> I've pushed the updated esp-idf status to our clone now, so we can start using that for release 007.
>> I've also checked the upstream master status again, which is already quite some commits ahead, including lots of wifi and bluetooth updates.
>> Unfortunately I got IRAM space issues and had to disable bluetooth to be able to build at all. The resulting firmware crashed immediately on wifi power up with
>> error code 0x102 and a message that we should use WIFI_INIT_CONFIG_DEFAULT. Which we do, I don't see anything wrong in our init code. So I switched back to the
>> working version for now.
>> To use the new esp-idf version all you need to do is a pull from our repository and a git submodule update. The xtensa tools are still the same.
>> Am 17.05.2018 um 10:41 schrieb Michael Balzer:
>>> Regarding the esp-idf update: it works without (new) issues and seems to improve stability a bit, but not as much as I was hoping.
>>> So it's an option, but not a priority for 006.
>>> Am 17.05.2018 um 05:06 schrieb Mark Webb-Johnson:
>>>> Deadline for the factory firmware is this weekend. The modules have all been built and are waiting sim cards, firmware flash, then final QC.
>>>> So, I suggest we freeze things as they are. I will double-check the wifi setup tonight (it seemed ok last time I checked, so hopefully good now). Build will not include the bluetooth code I am working on (that is disabled in our default sdkconfig anyway).
>>>> Is there anything else holding this up? Or anything anybody wants to rush in?
>>>> Regards, Mark.
>>>> OvmsDev mailing list
