[Ovmsdev] SD CARD speed vs cp2102
    Thu May 17 18:43:05 HKT 2018
It's sufficient to provide additional power to USB, but it needs to be a constant supply (the Twizy 12V port in the glove box is switched).
Am 17.05.2018 um 12:14 schrieb Michael Balzer:
> Is it sufficient to provide secondary power at the USB port or does the 12V supply needs to be detached?
> Am 17.05.2018 um 12:00 schrieb Mark Webb-Johnson:
>> Other option I tried is to power from USB. But maybe not so easy in a Twizy?
>> I should have new chips early next week. Arranging now.
>> Regards, Mark
>> On 17 May 2018, at 5:48 PM, Michael Balzer <dexter at expeedo.de <mailto:dexter at expeedo.de>> wrote:
>>> Wow. Confirmed, speedup is at least factor 5.
>>> And better yet, the fsync() overhead is reduced from ~50 ms to < 10 ms as well, the performance impact of SD logging is now fully acceptable for every day use.
>>> All of my beta testers use SD cards to provide debug logs. Some also have been doing CAN logging, which helped debug some timing issues.
>>> I'll need another 3.1 module anyway, but the testers will most likely want to continue using their modules. I'll forward your rework offer and the info on
>>> how to solve this themselves if they're capable of doing micro-soldering.
>>> Am 17.05.2018 um 10:40 schrieb Mark Webb-Johnson:
>>>> It is a lot faster when working correctly. To me, it seems much more than 25%. Maybe four or five times faster?
>>>> You can try:
>>>>     config set sdcard maxfreq.khz 20000
>>>> then reboot and power from USB. Then try your speed test. Perhaps vfs cp from SD to SD to test?
>>>> Regards, Mark.
>>>>> On 17 May 2018, at 4:15 PM, Michael Balzer <dexter at expeedo.de <mailto:dexter at expeedo.de>> wrote:
>>>>> Thanks for the analysis and solution!
>>>>> What kind of speedup is achievable by replacing the cp2102? Is it just linear 16 → 20 MHz = 25%?
>>>>> Or does this also solve hidden retransmission issues?
>>>>> balzer at leela:~/esp/Open-Vehicle-Monitoring-System-3/vehicle/OVMS.V3> time ssh dexze85.local "vfs ls /sd/logs"
>>>>>   541.7k  22-Apr-2018 22:34  can-180422
>>>>>   449.0k  17-May-2018 09:56  log
>>>>>   580.8k  01-May-2018 18:15  dm
>>>>>     1.0M  30-Apr-2018 00:51  log.20180430-005121
>>>>>     1.0M  30-Apr-2018 10:27  log.20180430-102732
>>>>>     1.0M  30-Apr-2018 19:41  log.20180430-194146
>>>>>     1.0M  01-May-2018 02:21  log.20180501-022128
>>>>>     1.0M  01-May-2018 11:03  log.20180501-110318
>>>>>      80   01-May-2018 14:09  can-180501
>>>>>     1.0M  01-May-2018 17:56  log.20180501-175658
>>>>>     1.1M  01-May-2018 18:17  dm2
>>>>>     2.0M  01-May-2018 18:28  dm3
>>>>>     1.3M  01-May-2018 20:21  dm4
>>>>>     1.0M  02-May-2018 04:06  log.20180502-040605
>>>>>     1.0M  02-May-2018 13:38  log.20180502-133816
>>>>>     1.0M  03-May-2018 00:04  log.20180503-000415
>>>>>     1.0M  03-May-2018 10:38  log.20180503-103815
>>>>>     1.0M  03-May-2018 19:46  log.20180503-194654
>>>>>     1.0M  04-May-2018 06:22  log.20180504-062242
>>>>>     1.0M  04-May-2018 17:23  log.20180504-172311
>>>>>     1.0M  05-May-2018 03:50  log.20180505-035002
>>>>>     1.0M  05-May-2018 15:01  log.20180505-150115
>>>>>     1.0M  06-May-2018 01:22  log.20180506-012241
>>>>>     1.0M  06-May-2018 09:42  log.20180506-094249
>>>>>     1.0M  06-May-2018 16:58  log.20180506-165842
>>>>>     1.0M  07-May-2018 02:08  log.20180507-020820
>>>>>     1.0M  07-May-2018 09:08  log.20180507-090846
>>>>>     1.0M  07-May-2018 13:10  log.20180507-131042
>>>>>   630.2k  23-Apr-2018 23:51  can-180423
>>>>>     1.0M  07-May-2018 16:40  log.20180507-164032
>>>>>     3.6M  24-Apr-2018 00:30  can-180424
>>>>>     1.0M  24-Apr-2018 01:09  log.20180424-010932
>>>>>     1.0M  24-Apr-2018 11:36  log.20180424-113642
>>>>>     1.0M  24-Apr-2018 18:41  log.20180424-184124
>>>>>     1.0M  25-Apr-2018 02:54  log.20180425-025415
>>>>>     1.0M  25-Apr-2018 13:10  log.20180425-131000
>>>>>     1.0M  25-Apr-2018 23:40  log.20180425-234048
>>>>>     1.0M  26-Apr-2018 08:23  log.20180426-082309
>>>>>     1.0M  26-Apr-2018 13:17  log.20180426-131718
>>>>>     1.0M  26-Apr-2018 17:32  log.20180426-173218
>>>>>     1.0M  26-Apr-2018 22:26  log.20180426-222645
>>>>>     1.0M  27-Apr-2018 06:19  log.20180427-061932
>>>>>     1.0M  27-Apr-2018 11:45  log.20180427-114534
>>>>>     1.0M  27-Apr-2018 16:07  log.20180427-160751
>>>>>     1.0M  28-Apr-2018 05:07  log.20180428-050703
>>>>>     1.0M  28-Apr-2018 14:39  log.20180428-143956
>>>>>     1.0M  29-Apr-2018 00:07  log.20180429-000755
>>>>>     1.0M  29-Apr-2018 10:26  log.20180429-102600
>>>>>     1.0M  29-Apr-2018 14:09  log.20180429-140942
>>>>>     1.0M  07-May-2018 18:39  log.20180507-183951
>>>>>     1.0M  07-May-2018 21:18  log.20180507-211821
>>>>>     1.0M  08-May-2018 01:06  log.20180508-010616
>>>>>     1.0M  08-May-2018 08:12  log.20180508-081232
>>>>>     1.0M  08-May-2018 13:31  log.20180508-133133
>>>>>     1.0M  08-May-2018 14:52  log.20180508-145232
>>>>>     1.0M  08-May-2018 15:55  log.20180508-155530
>>>>>     1.0M  08-May-2018 16:18  log.20180508-161814
>>>>>     1.0M  08-May-2018 16:33  log.20180508-163344
>>>>>     1.0M  08-May-2018 16:51  log.20180508-165156
>>>>>     1.0M  08-May-2018 18:40  log.20180508-184035
>>>>>     1.0M  09-May-2018 02:13  log.20180509-021338
>>>>>     1.0M  09-May-2018 11:28  log.20180509-112803
>>>>>     1.0M  09-May-2018 13:10  log.20180509-131042
>>>>>     1.0M  09-May-2018 13:30  log.20180509-133049
>>>>>     1.0M  09-May-2018 13:46  log.20180509-134607
>>>>>     1.0M  09-May-2018 14:02  log.20180509-140208
>>>>>     1.0M  09-May-2018 14:17  log.20180509-141725
>>>>>     1.0M  09-May-2018 14:31  log.20180509-143108
>>>>>     1.0M  09-May-2018 14:44  log.20180509-144407
>>>>>     1.0M  09-May-2018 14:58  log.20180509-145806
>>>>>     1.0M  09-May-2018 15:20  log.20180509-152009
>>>>>     1.0M  09-May-2018 18:59  log.20180509-185904
>>>>>     1.0M  10-May-2018 00:10  log.20180510-001018
>>>>>     1.0M  10-May-2018 09:11  log.20180510-091155
>>>>>     1.0M  10-May-2018 13:57  log.20180510-135727
>>>>>     1.0M  10-May-2018 21:50  log.20180510-215045
>>>>>     1.0M  11-May-2018 07:34  log.20180511-073403
>>>>>     1.0M  11-May-2018 13:24  log.20180511-132440
>>>>>     1.0M  11-May-2018 17:13  log.20180511-171332
>>>>>     1.0M  11-May-2018 22:00  log.20180511-220047
>>>>>     1.0M  12-May-2018 11:08  log.20180512-110827
>>>>>     1.0M  12-May-2018 15:30  log.20180512-153022
>>>>>     1.0M  12-May-2018 17:42  log.20180512-174248
>>>>>     1.0M  12-May-2018 22:29  log.20180512-222949
>>>>>     1.0M  13-May-2018 10:03  log.20180513-100341
>>>>>     1.0M  13-May-2018 14:26  log.20180513-142603
>>>>>     1.0M  13-May-2018 22:53  log.20180513-225343
>>>>>     1.0M  14-May-2018 07:58  log.20180514-075805
>>>>>     1.0M  14-May-2018 11:35  log.20180514-113524
>>>>>     1.0M  14-May-2018 16:27  log.20180514-162753
>>>>>     1.0M  15-May-2018 01:31  log.20180515-013153
>>>>>     1.0M  15-May-2018 08:58  log.20180515-085847
>>>>>     1.0M  15-May-2018 12:30  log.20180515-123053
>>>>>     1.0M  15-May-2018 18:24  log.20180515-182435
>>>>>     1.0M  16-May-2018 07:25  log.20180516-072553
>>>>>     1.0M  16-May-2018 08:55  log.20180516-085501
>>>>>     1.0M  16-May-2018 12:01  log.20180516-120115
>>>>>     1.0M  16-May-2018 19:46  log.20180516-194613
>>>>>     1.0M  17-May-2018 06:14  log.20180517-061451
>>>>> *real    0m18.965s*
>>>>> user    0m0.018s
>>>>> sys    0m0.009s
>>>>> Am 17.05.2018 um 04:22 schrieb Mark Webb-Johnson:
>>>>>> Good grief. A year into this, and still writing about SD CARD issues with ESP32. If I could get into a room with the engineer who decided to share boot
>>>>>> strapping pins with SDCARD pins, and to hard wire the SDIO controller to specific pins, I would literally try to slap some sense into him.
>>>>>> The China guys and I have been struggling for the past couple of months trying to work out why we can’t get as much speed out of the SD CARD as we
>>>>>> wanted. If we raise the speed to the normal 20MHz, we randomly get errors (timeouts, checksums, etc). It looked like interference on the bus lines, but
>>>>>> scoping those we can’t find any. Dropping the speed to 16MHz works around the issue, but SD CARD accesses are slow.
>>>>>> Then, we worked out it wasn’t random. It was based on whether we were powering from USB or external 12V. On the bench it works fine. In the car the
>>>>>> problem appears. Simply put, if the USB was plugged in the ‘interference’ disappeared. If USB was unplugged, it came back. USB + external 12V combination
>>>>>> also didn’t suffer from the issue, so the problem is not coming from the 12v side. The issue often appeared on only the second test of SD CARD, not the
>>>>>> first. We didn’t see this problem on either the v3.0 developer modules, or v3.1 prototypes.
>>>>>> We looked at the capacitors and pull-up resistors on that side of the circuit, without success. Whatever we did made little difference (or randomly
>>>>>> changed things for the better/worse). We thought maybe ground-line interference, but nope. We spent some time looking at C20, C22, C23 to see if the
>>>>>> manufacturers had messed up the component values - they hadn’t.
>>>>>> Anyway, to cut a long story short, we finally found the culprit. The CP2102 chip itself.
>>>>>> We’d already had to change the power supply design early on in the project to cope with a bug in CP2102 not correctly handling USB host disconnect and
>>>>>> not properly going into suspend mode (to reduce power consumption of cp2101 circuit when usb was disconnected) - our current design completely powers
>>>>>> down the cp2102 chip when the USB cable is disconnected. Michael Stegen had previously warned me about clones of this chip
>>>>>> (see https://wiki.sha2017.org/w/Projects:Badge and what they went through), and we had added the extra resistor already to cope with that eventuality.
>>>>>> But, from what we can tell this is not a clone part issue. Here is what we found:
>>>>>>  1. OVMS v3.0 and early v3.1 prototypes use CP2102 v1412+. For that chip, when the USB cable is disconnected, CSL-TXD is 3.3v.
>>>>>>  2. OVMS v3.1 first production batch use a newer CP2102 v1708+. For that chip, when the USB cable is disconnected, CSL-TXD is pulled down to 0.78v.
>>>>>>  3. We have replaced the cp2102 on a v3.1 first production module with v1412+, and SD CARD resumes normal operation (even with usb disconnected).
>>>>>>  4. The version number seems to be a date code. YYWW (year, week), I guess.
>>>>>>  5. We have absolutely no idea why this would be affecting the SD CARD performance or interference. Somehow, that CSL-TXD line is going through the ESP32
>>>>>>     chip and affecting the  SDIO controller (perhaps related to the bootstrapping pins dual use). The interference we see is inside the ESP32, not on the
>>>>>>     lines going from ESP32 to the SDCARD (which is why we couldn’t see it on the scope).
>>>>>> I tried shutting down the pins on the ESP32 for CSL-TXD and CSL-RXD, to see if I could work around the problem in firmware, but couldn’t get it to work.
>>>>>> There is no way of knowing whether the USB is connected, and even if we did know, setting CSL-TXD and CSL-RXD pins to output mode, or float, doesn’t seem
>>>>>> to make any difference.
>>>>>> The good news is that we’ve at least identified the problem. We are (a) checking the revision of cp2102 chip in the upcoming production batch, and (b)
>>>>>> changing QC procedures to set SD CARD bus speed to default (20MHz) and randomly test modules twice on 12V power. Latest production batch is now using
>>>>>> v1742+, and that has been tested as working. Going forward, we can resolve this.
>>>>>> As for the first production batch units, they are what they are. For normal SD CARD operation (copying files, flashing firmware, etc), it makes little
>>>>>> difference. I guess most users don’t even have an SD CARD inserted. The speed limitation really only becomes an issue if you are trying to log lots of
>>>>>> data to SD CARD (such as CAN bus dumps). If the USB is connected, you can 'config set sdcard maxfreq.khz 20000’ and it will work faster. The CP2102 chip
>>>>>> can be changed, and I’ll do that for anyone that needs it. I’m asking China to send me some from the latest production batch that we know works.
>>>>>> Replacement is relatively straightforward, but involves micro-soldering (the cp2102 is a surface mount chip, very small footprint, with lots of other
>>>>>> components near it on the board).
>>>>>> Regards, Mark.
>>>>>> OvmsDev mailing list
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20180517/776d0b97/attachment.htm>
