[Ovmsdev] Can buses stop after some time
Fri May 11 22:15:35 HKT 2018
Can you:
diff sdkconfig support/sdkconfig.default.hw31
and make sure the same? Maybe stack sizes are different?
Or maybe something in your vehicle type is using up a lot of stack. Try ‘module tasks’ to see.
> On 11 May 2018, at 9:42 PM, Robin O'Leary <ovmsdev at caederus.org> wrote:
> On Fri, May 11, 2018 at 08:08:10PM +0800, Mark Webb-Johnson wrote:
>> I think —tags is missing?
>> I normally ‘git fetch origin —tags as the first step.
> Ah, thanks, that fixed the the version label.
> My build still crashes though, this time with another stack overflow:
> OVMS# ***ERROR*** A stack overflow in task OVMS Vehicle has been detected.
> abort() was called at PC 0x40092f00 on core 1
> Backtrace: 0x40092cec:0x3ffdcaf0 0x40092ee7:0x3ffdcb10 0x40092f00:0x3ffdcb30 0x4008f33c:0x3ffdcb50 0x40090f90:0x3ffdcb70 0x40090f46:0xa5a5a5a5
> Rebooting...
> 0x40092cec invoke_abort + 24 in section .iram0.text
> 0x40092ee7 abort + 39 in section .iram0.text
> 0x40092f00 vApplicationStackOverflowHook + 20 in section .iram0.text
> 0x4008f33c vTaskSwitchContext + 200 in section .iram0.text
> 0x40090f90 _frxt_dispatch in section .iram0.text
> 0x40090f46 _frxt_int_exit + 70 in section .iram0.text
> btw, something helpfully mapped the character sequence "[dash][dash]tags"
> in your message to "[en-dash]tags"; if you cut-and-paste that directly
> to a command line, you get a rather confusing error:
> $ git fetch origin —tags
> fatal: Couldn't find remote ref —tags
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20180511/49ec1b4b/attachment.htm>
