[Ovmsdev] Can buses stop after some time
Robin O'Leary ovmsdev at caederus.org
Fri May 11 21:42:59 HKT 2018
On Fri, May 11, 2018 at 08:08:10PM +0800, Mark Webb-Johnson wrote:
> I think —tags is missing?
> I normally ‘git fetch origin —tags as the first step.
Ah, thanks, that fixed the the version label.
My build still crashes though, this time with another stack overflow:
OVMS# ***ERROR*** A stack overflow in task OVMS Vehicle has been detected.
abort() was called at PC 0x40092f00 on core 1
Backtrace: 0x40092cec:0x3ffdcaf0 0x40092ee7:0x3ffdcb10 0x40092f00:0x3ffdcb30 0x4008f33c:0x3ffdcb50 0x40090f90:0x3ffdcb70 0x40090f46:0xa5a5a5a5
Rebooting...
0x40092cec invoke_abort + 24 in section .iram0.text
0x40092ee7 abort + 39 in section .iram0.text
0x40092f00 vApplicationStackOverflowHook + 20 in section .iram0.text
0x4008f33c vTaskSwitchContext + 200 in section .iram0.text
0x40090f90 _frxt_dispatch in section .iram0.text
0x40090f46 _frxt_int_exit + 70 in section .iram0.text
btw, something helpfully mapped the character sequence "[dash][dash]tags"
in your message to "[en-dash]tags"; if you cut-and-paste that directly
to a command line, you get a rather confusing error:
$ git fetch origin —tags
fatal: Couldn't find remote ref —tags
Desc: Digital signature
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20180511/0ad0af50/attachment-0002.sig>
