[Ovmsdev] Production batch 2 and onwards
Wed May 2 19:40:19 HKT 2018
Michael,
> Regarding the CE/FCC certification, maybe we can raise some funds from the users interested in this, i.e. nearly all EU users. How much is it?
Certification lab is suggesting to do CE-RED and FCC-ID. The direct certificate test and consultancy charge is about US$2,000 for CE-RED, and US$4,000 for FCC-ID. Modifications to our circuit and test modules will probably cost not much at all (few hundred US$). Not sure about the actual certification filing fees (but I am told not excessive, and maybe able to negotiate with test lab). Also not sure about the other parts of CE, like WEEE (and still waiting for confirmation on that).
Those prices are for a China lab doing it, and seem about the going rate. The testing process itself is 1 to 2 weeks (plus whatever time we need to make revisions in order to pass). Doing it in china speeds up those revision times to a matter of days.
Financially, once the money for the first batch comes in fully, we can afford it out of project funds.
> Regarding the firmware deadline, 10 days may be a bit short for the wifi rework and new setup wizard to get done and mature enough for rollout. The web UI now checks for all common mistakes users made in their initial setup (I hope I got all of them…). I'll see if I can add a "quick setup" page of the main configuration options.
I think so too. For me, it depends on how well the wifi re-work I am doing goes. I should know that this week. I am trying to get it so that the module can be configured as AP + STA mode, and then either AP or STA brought up and down as necessary (including taking down the STA, doing a scan, then bringing it back up). But the ESP32 IDF library is not co-operating.
> We should replace the serial number process by the factory defaults (wifi AP "OVMS / OVMSinit", no shell password).
Yes. I will update the production notes and deal with factory for that. Should be fine, and much simpler for the user. But, need to get the prompt for password configuration during initial setup very clear to the user, to avoid this becoming a major vulnerability.
> On 2 May 2018, at 5:00 PM, Michael Balzer <dexter at expeedo.de> wrote:
> Mark,
> thanks for the update and your monetary support.
> Am 02.05.2018 um 08:24 schrieb Mark Webb-Johnson:
>> FYI
>> The order for production batch #2 has just been placed:
>> 50x US kits (module + US 3G modem + Hologram sim)
>> 150x EU kits (module + EU 3G modem + Hologram sim)
>> 20x modules only (board + case, but no modem)
>> 5x EU 3G modems (incl. Hologram sim)
>> 5x US 3G modems (incl. Hologram sim)
>> No change to specification and board layout from the first production batch, except to re-iterate the points that came in from feedback. We are arranging a foam box to ship the modules in, with our logo on it, to avoid the issues with sticky glue on those padded bags.
>> Availability at Fasttech perhaps in about 3 weeks time. Our deadline for firmware is about 10 days.
>> This is a lot of $$$ upfront payment, and the project is pretty tapped financially (I’ve had to pay for most of this myself). Once the money from sales starts to come in, we’ll be better off.
>> I have quotes from certification labs for CE and FCC certs, and it seems possible. They say we may have some small changes to make (ESD primarily), but overall our design seems fine and they are confident we can achieve the certification. The process is expensive, but is just a one off upfront payment. Current plan is to start with that process once we have this production batch built and at Fasttech. We did consider doing this before this production batch #2, but that would have just delayed things several months.
>> So long as this certification process doesn’t drag on, we should be able to keep OVMS v3 in stock and available from now.
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20180502/9aac0d1f/attachment.htm>
