[Ovmsdev] Mongoose update (git submodule update)
    Sat May 26 20:16:24 HKT 2018
I missed adding the mutex lock to mbuf_append() and mbuf_trim().
Fix is pushed, remember to also do "git submodule update".
Am 25.05.2018 um 09:29 schrieb Michael Balzer:
> Am 25.05.2018 um 04:01 schrieb Mark Webb-Johnson:
>> Michael,
>> This seems a very neat solution, at a fundamental level, to the problem. I just worry if there are other parts of mongoose (other than buffers) that are going to hit this multi-threaded issue. I think, for safety, we need to make sure as much as possible is done inside the mongoose task.
> Yes, that's an important note for all developers: *this does not make mongoose thread safe*.
> This only makes the connection buffer access thread safe so mg_send() can be called from other tasks, e.g. from event or metric listeners. This can be done if
> sends are atomic on the protocol level (as done in the v2 server by Transmit()). A clean "mongoose style" solution for this would be to queue all
> transmissions and only send from the mongoose event handler or a mongoose broadcast handler.
> All other concurrent accesses to mongoose connections still must be avoided. Even API calls that seem to only do read accesses (e.g. mg_conn_addr_to_str) can
> have hidden side effects if called from another context.
>> Please let us know if it solves the problem you are seeing.
> This was happening mostly on the Twizy because it currently does the most custom telemetry.
> Looks very good so far. I rolled out the build yesterday evening, so I will have some more data on this over the weekend.
>>> On 24 May 2018, at 11:30 PM, Michael Balzer <dexter at expeedo.de> wrote:
>>> Re: https://github.com/openvehicles/Open-Vehicle-Monitoring-System-3/issues/120
>>> I've pushed an update to our mongoose clone that should solve the spurious crashes in mbuf_insert().
>>> After the next git pull, you will also need to do a git submodule update.
>>> Please test for your setups and report if the crash still occurs or any new issues come up.
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20180526/249dc2df/attachment.html>
