[Ovmsdev] Fwd: [openvehicles/Open-Vehicle-Monitoring-System-3] 951f04: Support durations (default 1000ms) for homelink tr...
Tue May 15 21:27:26 HKT 2018
Did some off-list work with Steve and Greg on homelink. Turns out that there is really a ‘duration’ associated with homelink transmissions. For Tesla Roadster:
For single button presses, the duration is about 1,000ms.
Any transmission longer than about 10,000ms - 14,000ms is cut-off and aborted after that time.
If a button is held down, homelink continues to transmit (up to the maximum #2 above).
Accordingly, I’ve updated the homelink command, and vehicle modules that use it. Haven’t bothered to change the OVMS protocol v2 (as that can just use the default of 1000ms).
> Begin forwarded message:
> From: GitHub <noreply at github.com>
> Subject: [openvehicles/Open-Vehicle-Monitoring-System-3] 951f04: Support durations (default 1000ms) for homelink tr...
> Date: 15 May 2018 at 9:23:39 PM HKT
> To: mark at webb-johnson.net
> Reply-To: GitHub <noreply at github.com>
> Branch: refs/heads/master
> Home: https://github.com/openvehicles/Open-Vehicle-Monitoring-System-3
> Commit: 951f04587792c88682335ff938e83b6e071b5411
> https://github.com/openvehicles/Open-Vehicle-Monitoring-System-3/commit/951f04587792c88682335ff938e83b6e071b5411
> Author: Mark Webb-Johnson <mark at webb-johnson.net>
> Date: 2018-05-15 (Tue, 15 May 2018)
> Changed paths:
> M vehicle/OVMS.V3/components/vehicle/vehicle.cpp
> M vehicle/OVMS.V3/components/vehicle/vehicle.h
> M vehicle/OVMS.V3/components/vehicle_demo/src/vehicle_demo.cpp
> M vehicle/OVMS.V3/components/vehicle_demo/src/vehicle_demo.h
> M vehicle/OVMS.V3/components/vehicle_nissanleaf/src/vehicle_nissanleaf.cpp
> M vehicle/OVMS.V3/components/vehicle_nissanleaf/src/vehicle_nissanleaf.h
> M vehicle/OVMS.V3/components/vehicle_teslaroadster/src/vehicle_teslaroadster.cpp
> M vehicle/OVMS.V3/components/vehicle_teslaroadster/src/vehicle_teslaroadster.h
> Log Message:
> Support durations (default 1000ms) for homelink transmissions.
> **NOTE:** This service been marked for deprecation: https://developer.github.com/changes/2018-04-25-github-services-deprecation/
> Functionality will be removed from GitHub.com on January 31st, 2019.
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20180515/2fdfb2f7/attachment.html>
