[Ovmsdev] esp-idf release 3.0 / master
Sat May 12 03:39:20 HKT 2018
If no "module memory" or "module tasks" command has been executed then
the 32-bit RAM allocation that you see under NetMan task won't have
been allocated, so for typical users there should still be plenty of
free 32-bit RAM in case the system decides it needs some at a later
time for some infrequent operation.  If a memory diagnostic command is
issued at a time when 32-bit RAM has been used for something else, the
allocation will back off to 8-bit RAM which should work fine on v3.1
hardware.  We developers might see a problem if memory diagnostics
have been used and then some infrequent event needing 32-bit memory
occurs.
I implemented the 32-bit memory allocation for the v3.0 hardware since
I couldn't afford to use all the 8-bit memory for diagnostics and I
could make my code tolerate the lack of 8-bit access.  I could make my
code try SPIRAM first so that the 32-bit memory would be kept free on
v3.1 hardware.  That is, unless we consider the 32-bit memory
otherwise wasted and want to keep as much SPIRAM available as we can.
On Fri, 11 May 2018, Michael Balzer wrote:
> "module memory" doesn't show the allocation under "no task".
> Up to now there have been no issues resulting from the low 32 bit RAM, the module has been running all day long, with all com channels and on multiple test
> drives & charges without a single crash or other problem. Looks really good.
> I think I'll roll out the build on my server to get some field results.
> Am 11.05.2018 um 17:13 schrieb Stephen Casner:
> > There are two possibilities:
> > 1) The size of the 32-bit heap region may have been reduced because
> > there is more code stored in RAM (perhaps for flash manipulation).
> > 2) If the extra 32-bit RAM has been allocated from the heap, then
> > "module memory" would show it under "no task".
> >                                                         -- Steve
> >> Update:
> >> Am 11.05.2018 um 09:52 schrieb Michael Balzer:
> >>> According to the task monitor the new 32 bit allocations account to the NetMan task:
> >> Nope, the 32 bit usage of the NetMan task is the same as before. So the additional usage is outside the scope of our memory tracking, so must be a system
> >> component -- correct, Steve?
> >> Regards,
> >> Michael
> >> Michael Balzer * Helkenberger Weg 9 * D-58256 Ennepetal
> >> Fon 02333 / 833 5735 * Handy 0176 / 206 989 26
> > OvmsDev mailing list
