[Ovmsdev] Can buses stop after some time
Robin O'Leary
ovmsdev at caederus.org
Fri May 11 19:47:10 HKT 2018
On Fri, May 11, 2018 at 10:22:00PM +1200, Tom Parker wrote:
> I synced up with master about a week ago and since then I've seen both can
> busses stop working. I still see the 12v battery metric changing, but
> everything that comes from the car stops. Rebooting the module with "module
> reset" does not seem to fix it, while make app-flash monitor does fix it. I
> haven't tried make monitor on it's own.
> Is anyone else seeing behavior like this?
Hmm, not quite the same symptoms, but I have also been seeing some
instability after an update maybe 2--3 days ago, when only the EV bus
stopped working, so I wonder if this is related.
Things got much worse after an update from master this morning: now my
own build consistently crashes. The first crash I managed to log was
a stack overflow abort:
OVMS# event trace on
Event tracing is now on
OVMS# ***ERROR*** A stack overflow in task OVMS Vehicle has been detected.
abort() was called at PC 0x40092f00 on core 1
Backtrace: 0x40092cec:0x3ffdb580 0x40092ee7:0x3ffdb5a0 0x40092f00:0x3ffdb5c0 0x4008f306:0x3ffdb5e0 0x40090f90:0x3ffdb600 0x40090f46:0x00000000
Rebooting...
That was with some of my own changes on top, so I reverted to a clean
checkout from master and got a different crash:
Guru Meditation Error: Core 1 panic'ed (StoreProhibited)
. Exception was unhandled.
Core 1 register dump:
PC : 0x4021292f PS : 0x00060d30 A0 : 0x800e7970 A1 : 0x3ffbf7b0
A2 : 0x3ffdd218 A3 : 0x3ffdb5ec A4 : 0x3ffbf7e8 A5 : 0x0000000c
A6 : 0x00000000 A7 : 0xff000000 A8 : 0xbaad5678 A9 : 0x3ffbf790
A10 : 0x3ffdd218 A11 : 0x40085228 A12 : 0x00000000 A13 : 0x3ff6b000
A14 : 0x00000000 A15 : 0x00000001 SAR : 0x00000004 EXCCAUSE: 0x0000001d
EXCVADDR: 0xbaad5678 LBEG : 0x40098c89 LEND : 0x40098cad LCOUNT : 0x800e6d0c
Backtrace: 0x4021292f:0x3ffbf7b0 0x400e796d:0x3ffbf7d0 0x4012218e:0x3ffbf830 0x40122839:0x3ffbfe60 0x400f3440:0x3ffbfeb0 0x400f357d:0x3ffbff40 0x400ee421:0x3ffbff80 0x400eedf1:0x3ffbffb0 0x400eeef1:0x3ffc0060 0x400eef01:0x3ffc0090
gdb info symbol decodes these as:
0x4021292f std::__detail::_List_node_base::_M_hook(std::__detail::_List_node_base*) + 11 in section .flash.text
0x400e796d OvmsMetrics::RegisterListener(char const*, char const*, std::function<void (OvmsMetric*)>) + 241 in section .flash.text
0x4012218e OvmsServerV2::OvmsServerV2(char const*) + 554 in section .flash.text
0x40122839 OvmsServerV2Init::AutoInit() + 101 in section .flash.text
0x400f3440 Housekeeping::Init(std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> >, void*) + 548 in section .flash.text
0x400f357d std::_Function_handler<void (std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> >, void*), std::_Bind<std::_Mem_fn<void (Housekeeping::*)(std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> >, void*)> (Housekeeping*, std::_Placeholder<1>, std::_Placeholder<2>)> >::_M_invoke(std::_Any_data const&, std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> >&&, void*&&) + 133 in section .flash.text
0x400ee421 std::function<void (std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> >, void*)>::operator()(std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> >, void*) const + 29 in section .flash.text
0x400eedf1 OvmsEvents::HandleQueueSignalEvent(event_queue_t*) + 161 in section .flash.text
0x400eeef1 OvmsEvents::EventTask() + 37 in section .flash.text
0x400eef01 EventLaunchTask(void*) + 5 in section .flash.text
I tried the stock auto-ota image files, and both 'main' and 'edge' were OK.
But now I am a bit confused about versions: the stock images both report
version 3.1.005, but even after updating, my own build reports 3.1.004.
Is there something else I need to do to fully update?
$ git pull --rebase upstream master
From https://github.com/openvehicles/Open-Vehicle-Monitoring-System-3
* branch master -> FETCH_HEAD
Already up to date.
Current branch master is up to date.
$ git submodule update
$ git describe
3.1.004-194-ge3b0765
Desc: Digital signature
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20180511/d6d6237e/attachment.sig>
