[Ovmsdev] Can buses stop after some time
Fri May 11 19:32:33 HKT 2018
The commands:
  can can1 status
  can can2 status
Show detailed stats on can drivers. Run once. Wait 10 seconds. Then run again to compare numbers.
> On 11 May 2018, at 6:22 PM, Tom Parker <tom at carrott.org> wrote:
> Hi all,
> I synced up with master about a week ago and since then I've seen both can busses stop working. I still see the 12v battery metric changing, but everything that comes from the car stops. Rebooting the module with "module reset" does not seem to fix it, while make app-flash monitor does fix it. I haven't tried make monitor on it's own.
> Is anyone else seeing behavior like this?
> Sorry for the vague bug report. I'll spend some time later this weekend to try to gather more information.
