[Ovmsdev] Fwd: [openvehicles/Open-Vehicle-Monitoring-System-3] 29e333: Issue #36: Add support for ota/tag in config
Robin O'Leary
ovmsdev at caederus.org
Fri May 11 16:34:21 HKT 2018
On Mon, Apr 16, 2018 at 09:13:33AM +0800, Mark Webb-Johnson wrote:
> A few changes to OTA this morning:
> The ‘ota status’ command used to check available server version only if a WIFI network was up. It now does that if ANY network is up (including modem).
> I’ve added a config instance ‘tag’ to parameter ‘ota’. This can be used to override the ota tag (default: main) at run-time.
Something unexpected happens if the server/version/tag doesn't exist:
OVMS# ota status
Running partition: ota_1
Boot partition: ota_1
Firmware: 3.1.004-193-g0d5cc93/ota_1/ro2 (build idf v3.1-dev-454-gdaef4b5c May 11 2018 07:58:30)
Server Available: <!DOCTYPE html> (is newer)
<head>
<meta charset="utf-8" />
<link rel="shortcut icon" href="http://api.openvehicles.com/sites/default/files/favicon_0.ico" type="image/vnd.microsoft.icon" />
<meta name="viewport" content="width=device-width, initial-scale=1, maximum-scale=1" />
<title>Page not found | Open Vehicles</title>
... followed by a couple more pages of html, including:
<div class="content">
The requested page "/firmware/ota/v3.1/ro2/ovms3.ver" could not be found. </div>
Fair enough that it didn't find an update as I'm using my own unique
CONFIG_OVMS_VERSION_TAG "ro2", but it shouldn't mistake the html error
page as a valid result.
Suggested fix:
diff --git a/vehicle/OVMS.V3/components/ovms_ota/src/ovms_ota.cpp b/vehicle/OVMS.V3/components/ovms_ota/src/ovms_ota.cpp
index 226f502..9ed0b6a 100644
--- a/vehicle/OVMS.V3/components/ovms_ota/src/ovms_ota.cpp
+++ b/vehicle/OVMS.V3/components/ovms_ota/src/ovms_ota.cpp
@@ -586,7 +586,7 @@ void OvmsOTA::GetStatus(ota_info& info, bool check_update /*=true*/)
url.append("/ovms3.ver");
OvmsHttpClient http(url);
- if (http.IsOpen() && http.BodyHasLine())
+ if (http.IsOpen() && http.ResponseCode() == 200 && http.BodyHasLine())
info.version_server = http.BodyReadLine();
char rbuf[512];
Desc: Digital signature
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20180511/4c3bd520/attachment.sig>
