[Ovmsdev] New Zealand Cellular Frequencies
Tom Parker
tom at carrott.org
Sun Mar 25 04:00:07 HKT 2018
Hi,
In New Zealand we have 3 3G cell phone networks: 2degrees & Vodafone use
900MHz with 2100MHz infill. Spark uses 850MHz with 2100MHz infill. The
European v3 modem supports 900MHz & 2100MHz while the US modem supports
850MHz & 1900MHz.
I can confirm the European OVMS v3 does not work at all well on Spark's
network in Auckland. It works well on 2degrees and I'm assuming also on
Vodafone (but I haven't tested).
The US OVMS v3 might work on Spark, but I don't know how many places
Spark have holes in their 850MHz network that are filled by 2100MHz
(possibly no such hole exists). The US model will probably also on
Vodafone's 900MHz 2G network (which they say they are keeping up until
2025), but I haven't tested either of these.
If you're in New Zealand, you might be able to get away with the US
modem on Spark 3G or on Vodafone 2G. Otherwise you'll have to wait for
the EU modem to be in stock again.
