[Ovmsdev] NetManTask created twice
Wed Mar 21 03:36:13 HKT 2018
I need to check if everything gets cleaned up in the webserver on "network.mgr.stop".
I currently rely on mongoose sending all connections an MG_EV_CLOSE on shutdown, and I haven't checked if that is that guaranteed to happen.
But that could only lead to a memory leak if the netman instance would be shut down while serving a file (ROM/SD) or command result.
Am 20.03.2018 um 07:53 schrieb Stephen Casner:
> The example I showed is with all your committed changes included.
> I expected only one NetManTask at a time, but I did not realize it
> would be stopped and restarted. It would be nice to know what memory
> is allocated but not freed. It may not be leaked if it is for
> resources that are used by other tasks, but still it would be nice to
> have all the memory properly accounted for.
> Below is my startup sequence. This may be AP auto-starting and then
> stopping, followed by client mode starting from my script. Without
> the modem running, there might be no interfaces up between those two
> operations.
> -- Steve
> Welcome to the Open Vehicle Monitoring System (OVMS) - Async Console
> I (1982) ovms-mdns: Starting MDNS
> I (1982) ssh: Launching SSH Server
> I (2012) version: Set version
> I (2012) script: Running script /store/events/system.start/startmeup
> I (2012) wifi: flush txq
> I (2012) wifi: stop sw txq
> I (2012) wifi: lmac stop hw txq
> I (2022) wifi: Deinit lldesc rx mblock:4
> I (2022) wifi: wifi firmware version: ebd3e5d
> I (2022) wifi: config NVS flash: enabled
> I (2022) wifi: config nano formating: disabled
> I (2022) system_api: Base MAC address is not set, read default base MAC address from BLK0 of EFUSE
> I (2032) wifi: Init dynamic tx buffer num: 16
> I (2032) wifi: Init data frame dynamic rx buffer num: 16
> I (2032) wifi: Init management frame dynamic rx buffer num: 16
> I (2032) wifi: wifi driver task: 3ffe5ea0, prio:23, stack:4096
> I (2032) wifi: Init static rx buffer num: 4
> I (2032) wifi: Init dynamic rx buffer num: 16
> I (2032) wifi: wifi power manager task: 0x3ffe7e14 prio: 21 stack: 2560
> I (2042) wifi: mode : sta (30:ae:a4:37:1b:84)
> I (2042) netmanager: WIFI access point is down
> I (2052) esp32wifi: AP stopped
> Starting WIFI as a client to Revelstoke...
> I (2072) simcom: State: Enter CheckPowerOff state
> I (2242) webserver: Stopping Web Server
> I (2242) telnet: Stopping Telnet Server
> I (2242) ssh: Stopping SSH Server
> I (4462) wifi: n:1 0, o:1 0, ap:255 255, sta:1 0, prof:1
> I (5112) wifi: state: init -> auth (b0)
> I (5122) wifi: state: auth -> assoc (0)
> I (5132) wifi: state: assoc -> run (10)
> I (5172) wifi: connected with Revelstoke, channel 1
> I (6692) event: sta ip: 192.168.1.84, mask: 255.255.255.0, gw: 192.168.1.254
> I (6702) netmanager: Interface priority is st2 (192.168.1.84/255.255.255.0 gateway 192.168.1.254)
> I (6702) netmanager: WIFI client up (with MODEM down): starting network with WIFI client
> I (6702) time: Starting SNTP client
> I (6712) esp32wifi: WiFi UP with SSID: Revelstoke, MAC: 30:ae:a4:37:1b:84, IP: 192.168.1.84, mask: 255.255.255.0, gw: 192.168.1.254
> I (6712) webserver: Launching Web Server
> I (6732) telnet: Launching Telnet Server
> I (6742) ssh: Launching SSH Server
> I (8132) wifi: pm start, type:0
> I (12062) housekeeping: System considered stable (free: 31760 bytes)
> I (16002) simcom: State timeout, transition to 13
> I (16002) simcom: State: Enter PoweredOff state
> I (16002) gsm-mux: Stop MUX
