Tue Mar 20 17:05:36 HKT 2018
Which firmware version is this with?
> On 20 Mar 2018, at 5:01 PM, Tom Parker <tom at carrott.org> wrote:
> Hi Mark,
> I'm back using the 2degrees simcard (they run a 900MHz/2100MHz network that is compatible with my simcom module) and performance is very good compared to where we were a few weeks ago. There is a dead spot which I drive through often where it would usually disconnect and never reconnect, now it still disconnects and I can see the app shows the last contact lag by a couple of minutes, but it reconnected all by itself.
> Unfortunately it dropped offline and never reconnected this evening. It disconnected shortly before I arrived at a meeting, I left the data logger connected for a few hours before trying "power simcom off" and on again which wasn't enough to clear it, I had to reboot the module the button. See attached log.
> <ovms_2018-03-20T04_40_03+0000.log.bz2>
