[Ovmsdev] Auto start/init (was Re: Crash / reboot loop with log level Info)
Sun Mar 4 18:29:14 HKT 2018
Greg,
thanks for testing & feedback.
I'm working on the Twizy web UI now. If you'd like to implement the obd2ecu configuration, add it to the obd2ecu module. Have a look at the rt_web module for an
example on how to extend the webserver from another module, it's really easy.
For the PID mapping, I think a tabular form like for the Wifi config would be suitable. You can copy that form as a template, it's in the web_cfg module and
consists of three methods:
* HandleCfgWifi -- main handler & Javascript
* OutputWifiTable -- table view
* UpdateWifiTable -- table controller
The Javascript for adding and deleting table rows can be used for any table form, you just need to change the row template.
Am 04.03.2018 um 04:47 schrieb Greg D.:
> Hi Michael,
> Looks good!
> The order for starting the obdii ecu task and the vehicle it draws data from isn't critical; nothing bad will happen if by some chance the OBDII device starts
> requesting information before the vehicle task makes it available. I suppose, the "most correct" sequence would start the vehicle task, then the obdii ecu
> task, then enable the ext12v power last, but in practice and by design there is no issue with starting any of them in pretty much any order. Worst case, the
> device it would get zeros if it wins the race, but I catch those internally and prevent the apparent lack of a running ICE engine from causing the device to
> shut down by supplying dummy information.
> The only thing missing in the web server, I suppose, would be a way to customize the PID-to-Metric mapping. I supply a default for the most common ones, but
> there are many more possible if you are using, say, an ELM 327 dongle with Torque-like application. Changing the mapping is easily done through the shell
> (unless you want to tackle that with the web server too). 'config set obd2ecu.map <pid> <metric>' to set the mapping, and 'obdii ecu list' to display the
> mapping and current values.
> Thanks for doing this!
> Greg
> Michael Balzer wrote:
>> Greg,
>> I've just added ext12v and obd2ecu to the auto init system & web config.
>> So except for the metric set command, you should now be able to start your module without a script.
>> The autostart sequence is slightly different from yours, the obd2ecu init is done after the vehicle module init, as I see the vehicle module as the data
>> provider for the obd2ecu module -- correct me if I'm wrong.
>> Can you please verify the start sequence is working as expected?
>> Am 25.02.2018 um 22:08 schrieb Greg D.:
>>> Here's my system.start event file:
>>> OVMS > vfs cat /store/events/system.start/mystartup
>>> obdii ecu start can3
>>> power ext12v on
>>> wifi mode client gregnet3
>>> # power simcom on
>>> vehicle module TR
>>> server v2 start
>>> metric set v.b.soc 55
>>> OVMS >
>>> (Before you ask, the setting of the soc metric is so that I can see the server is actually talking to the module, when the module's on the bench.)
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20180304/8574ac19/attachment.htm>
