[Ovmsdev] v3 at fasttech.com
Sun Mar 25 09:21:28 HKT 2018
Tom,
I’ve asked Fasttech to amend the title, to avoid confusion. The frequency bands listed in the detail are correct.
> On 25 Mar 2018, at 3:49 AM, Tom Parker <tom at carrott.org> wrote:
> On 25/03/18 02:38, Mark Webb-Johnson wrote:
>> I’ve asked Fasttech to remove the PICKITs from the ‘related parts’.
> Regarding the FastTech listing, does the US model have the SIM5360 modem, and the European model have the SIM5360E modem? On FastTech they both have the same modem in the headline listing, which I think is wrong.
> In the details section of the listing, you should repeat the 3G capabilities that are implied elsewhere. If you only read the details you might think it can only do "2G (GSM/GPRS) and 2.5G (EDGE) quad band". Add a line "3G UMTS/HSPA+ 900/2100MHz" (and the appropriate frequencies for the US model) immediately above the 2G line.
> You might want to modify the title to add "with" as it looks a little like it's only the modem module: OVMS v3.1 with SIM5360E 3G Modem Module (EU Edition)" and along the same lines, add an explanation to the package content, say:
> Package Contents: 1*OVMS 3.1 with EU Modem Module.
> Sold out already! I better push these Leaf improvements I started last week.
