[Ovmsdev] Test results of latest changes
Wed Mar 21 01:30:52 HKT 2018
Commit a9bfcc761e8853a5ad1e7cee4b966d012fc33895
…every (!) mode is working now! :-)
Wifi client, ap, apclient, also with MDNS enabled, switching networks, using the webserver via any net and using the MDNS name -- everything works.
RAM is as tight as before, had one out of memory crash in apclient mode with MDNS, but I also still have memory debugging enabled.
MDNS has a memory overhead of 3-8 KB depending on the wifi mode, so I also consider disabling it again for my 3.0 module.
I also haven't seen any strange things in the task list or memory leak during the test.
This looks very good.
Am 20.03.2018 um 08:49 schrieb Michael Balzer:
> Yes, RAM on hw3.0 is very tight now. Greg, you can save around 7 KB by not inserting an SD card.
> My normal free RAM is around 22 KB after mounting an SD card, which normally still works if I take care not to stress it by additional web / telnet sessions.
> Greg, if you enable debug log level for "webserver" and "webcommand" you will get free RAM log entries on pages and command calls.
> I'll try the latest changes as soon as I get home.
