Tue Mar 20 18:56:30 HKT 2018
Ah, that’s quite old (since when is two days old, he says :-)
But it pre-dates the 2bcbc8e995977c904f5346c44221e07413e56a62 stuff that messed things up.
Do you know at about what time (in the log file) the issue happened? Also, do you have a ‘simcom status’ from the issue time?
> On 20 Mar 2018, at 5:07 PM, Tom Parker <tom at carrott.org> wrote:
> Sorry I should have specified, it's with 15933a41ddca3a28d37ab788916b93480574447a with a few hopefully unrelated leaf specific changes I'm preparing to send though.
> On 20/03/18 22:05, Mark Webb-Johnson wrote:
>> Which firmware version is this with?
>> Regards, Mark
>>> On 20 Mar 2018, at 5:01 PM, Tom Parker <tom at carrott.org> wrote:
>>> Hi Mark,
>>> I'm back using the 2degrees simcard (they run a 900MHz/2100MHz network that is compatible with my simcom module) and performance is very good compared to where we were a few weeks ago. There is a dead spot which I drive through often where it would usually disconnect and never reconnect, now it still disconnects and I can see the app shows the last contact lag by a couple of minutes, but it reconnected all by itself.
>>> Unfortunately it dropped offline and never reconnected this evening. It disconnected shortly before I arrived at a meeting, I left the data logger connected for a few hours before trying "power simcom off" and on again which wasn't enough to clear it, I had to reboot the module the button. See attached log.
>>> <ovms_2018-03-20T04_40_03+0000.log.bz2>
