Tom Parker tom at carrott.org
Tue Mar 20 17:07:55 HKT 2018
Sorry I should have specified, it's with
15933a41ddca3a28d37ab788916b93480574447a with a few hopefully unrelated
leaf specific changes I'm preparing to send though.
On 20/03/18 22:05, Mark Webb-Johnson wrote:
> Which firmware version is this with?
> Regards, Mark
>> On 20 Mar 2018, at 5:01 PM, Tom Parker <tom at carrott.org> wrote:
>> Hi Mark,
>> I'm back using the 2degrees simcard (they run a 900MHz/2100MHz network that is compatible with my simcom module) and performance is very good compared to where we were a few weeks ago. There is a dead spot which I drive through often where it would usually disconnect and never reconnect, now it still disconnects and I can see the app shows the last contact lag by a couple of minutes, but it reconnected all by itself.
>> Unfortunately it dropped offline and never reconnected this evening. It disconnected shortly before I arrived at a meeting, I left the data logger connected for a few hours before trying "power simcom off" and on again which wasn't enough to clear it, I had to reboot the module the button. See attached log.
>> <ovms_2018-03-20T04_40_03+0000.log.bz2>
