[Ovmsdev] ota questions
Greg D.
gregd2350 at gmail.com
Sun Mar 18 12:35:25 HKT 2018
URL: <http://lists.teslaclub.hk/pipermail/ovmsdev/attachments/20180317/31d5d76d/attachment-0001.html>
W (2017444) simcom: 3 minutes since last MUX rx frame - assume MUX has failed
I (2017444) gsm-ppp: Shutting down (soft)...
I (2017444) netmanager: Interface priority is st1 (192.168.43.49/255.255.255.0 gateway 192.168.43.1)
I (2017444) time: Restarting SNTP client
I (2017444) ovms-server-v2: Network is reconfigured, so disconnect network connection
E (2017444) ovms-server-v2: Status: Error: Disconnected from OVMS Server V2
I (2017454) gsm-nmea: Shutdown (direct)
I (2017454) gsm-mux: Stop MUX
I (2017454) simcom: Power Cycle
I (2018454) simcom: State: Enter PoweringOn state
I (2018454) simcom: Power Cycle
I (2026444) simcom: State timeout, transition to 2
I (2026444) simcom: State: Enter PoweringOn state
I (2026444) simcom: Power Cycle
I (2028974) gsm-ppp: StatusCallBack: User Interrupt
I (2028974) gsm-ppp: PPP connection has been closed
I (2032214) simcom: State: Enter PoweredOn state
I (2036444) ovms-server-v2: Connection is tmc.openvehicles.com:6867 ROADSTER_834/Gdbkt2017server
I (2036444) ovms-server-v2: Status: Connecting...
W (2046134) ovms-server-v2: Connection failed
E (2046134) ovms-server-v2: Status: Error: Disconnected from OVMS Server V2
I (2051464) simcom: State: Enter MuxStart state
I (2051464) gsm-mux: Start MUX
I (2051474) gsm-mux: Channel #0 is open
I (2051484) gsm-mux: Channel #1 is open
I (2051494) gsm-mux: Channel #2 is open
I (2051494) gsm-mux: Channel #3 is open
-------- oops spoke too fast... Now the server connection has hung.
I (2051504) gsm-mux: Channel #4 is open
I (2052444) simcom: State: Enter NetWait state
I (2056444) simcom: State: Enter NetStart state
I (2065444) ovms-server-v2: Connection is tmc.openvehicles.com:6867 ROADSTER_834/Gdbkt2017server
I (2065444) ovms-server-v2: Status: Connecting...
W (2075134) ovms-server-v2: Connection failed
E (2075134) ovms-server-v2: Status: Error: Disconnected from OVMS Server V2
I (2085444) simcom: State timeout, transition to 7
I (2085444) simcom: State: Enter NetLoss state
I (2085444) gsm-ppp: Shutting down (hard)...
I (2085444) gsm-ppp: StatusCallBack: User Interrupt
I (2085444) gsm-ppp: PPP connection has been closed
I (2094444) ovms-server-v2: Connection is tmc.openvehicles.com:6867 ROADSTER_834/Gdbkt2017server
I (2094444) ovms-server-v2: Status: Connecting...
I (2095444) simcom: State timeout, transition to 5
I (2095444) simcom: State: Enter NetWait state
I (2099444) simcom: State: Enter NetStart state
W (2104134) ovms-server-v2: Connection failed
E (2104134) ovms-server-v2: Status: Error: Disconnected from OVMS Server V2
I (2123444) ovms-server-v2: Connection is tmc.openvehicles.com:6867 ROADSTER_834/Gdbkt2017server
I (2123444) ovms-server-v2: Status: Connecting...
I (2128444) simcom: State timeout, transition to 7
I (2128444) simcom: State: Enter NetLoss state
I (2128444) gsm-ppp: Shutting down (hard)...
I (2128444) gsm-ppp: StatusCallBack: User Interrupt
I (2128444) gsm-ppp: PPP connection has been closed
W (2133134) ovms-server-v2: Connection failed
E (2133134) ovms-server-v2: Status: Error: Disconnected from OVMS Server V2
I (2138444) simcom: State timeout, transition to 5
I (2138444) simcom: State: Enter NetWait state
I (2142444) simcom: State: Enter NetStart state
I (2152444) ovms-server-v2: Connection is tmc.openvehicles.com:6867 ROADSTER_834/Gdbkt2017server
I (2152444) ovms-server-v2: Status: Connecting...
W (2162134) ovms-server-v2: Connection failed
E (2162134) ovms-server-v2: Status: Error: Disconnected from OVMS Server V2
I (2171444) simcom: State timeout, transition to 7
I (2171444) simcom: State: Enter NetLoss state
I (2171444) gsm-ppp: Shutting down (hard)...
I (2171444) gsm-ppp: StatusCallBack: User Interrupt
I (2171444) gsm-ppp: PPP connection has been closed
I (2181444) simcom: State timeout, transition to 5
I (2181444) simcom: State: Enter NetWait state
I (2181444) ovms-server-v2: Connection is tmc.openvehicles.com:6867 ROADSTER_834/Gdbkt2017server
I (2181444) ovms-server-v2: Status: Connecting...
I (2185444) simcom: State: Enter NetStart state
W (2191134) ovms-server-v2: Connection failed
E (2191134) ovms-server-v2: Status: Error: Disconnected from OVMS Server V2
OVMS >
