[Ovmsdev] ota questions
Greg D.
gregd2350 at gmail.com
Sun Mar 18 12:30:10 HKT 2018
URL: <http://lists.teslaclub.hk/pipermail/ovmsdev/attachments/20180317/36a8e89d/attachment-0001.html>
--------- Note: Continuing on... Turned on Wifi hotspot here
I (1340564) wifi: n:1 1, o:1 0, ap:1 1, sta:1 0, prof:1
I (1341214) wifi: state: init -> auth (b0)
I (1341224) wifi: state: auth -> assoc (0)
I (1341234) wifi: state: assoc -> run (10)
I (1341264) wifi: connected with gregnet3, channel 1
I (1344654) event: sta ip: 192.168.43.49, mask: 255.255.255.0, gw: 192.168.43.1
I (1344654) netmanager: Set DNS#0 9.9.9.9
I (1344654) netmanager: Set DNS#1 8.8.8.8
I (1344654) netmanager: Interface priority is st1 (192.168.43.49/255.255.255.0 gateway 192.168.43.1)
I (1344654) time: Starting SNTP client
I (1344664) esp32wifi: WiFi UP with SSID: gregnet3, MAC: 30:ae:a4:37:1b:64, IP: 192.168.43.49, mask: 255.255.255.0, gw: 192.168.43.1
W (1357444) simcom: 3 minutes since last MUX rx frame - assume MUX has failed
I (1357444) gsm-ppp: Shutting down (soft)...
I (1357444) netmanager: Interface priority is st1 (192.168.43.49/255.255.255.0 gateway 192.168.43.1)
I (1357444) time: Restarting SNTP client
I (1357444) ovms-server-v2: Network is reconfigured, so disconnect network connection
E (1357444) ovms-server-v2: Status: Error: Disconnected from OVMS Server V2
I (1357454) gsm-nmea: Shutdown (direct)
I (1357454) gsm-mux: Stop MUX
I (1357454) simcom: Power Cycle
I (1358464) simcom: State: Enter PoweringOn state
I (1358464) simcom: Power Cycle
I (1358594) simcom: State: Enter PoweredOn state
I (1366444) simcom: State timeout, transition to 2
I (1366444) simcom: State: Enter PoweringOn state
I (1366444) simcom: Power Cycle
I (1368954) gsm-ppp: StatusCallBack: User Interrupt
I (1368954) gsm-ppp: PPP connection has been closed
I (1372284) simcom: State: Enter PoweredOn state
I (1372364) wifi: station: 40:4e:36:8a:44:c0 leave, AID = 1
I (1372364) wifi: n:1 0, o:1 1, ap:1 1, sta:1 0, prof:1
I (1372364) esp32wifi: AP station disconnected: id: 1, MAC: 40:4e:36:8a:44:c0
I (1375584) wifi: n:1 0, o:1 0, ap:1 1, sta:1 0, prof:1
I (1375584) wifi: station: 40:4e:36:8a:44:c0 join, AID=1, g, 20
I (1375584) esp32wifi: AP station connected: id: 1, MAC: 40:4e:36:8a:44:c0
I (1376444) ovms-server-v2: Connection is tmc.openvehicles.com:6867 ROADSTER_834/Gdbkt2017server
I (1376444) ovms-server-v2: Status: Connecting...
I (1377194) ovms-server-v2: Connection successful
I (1377194) ovms-server-v2: Status: Logging in...
I (1377194) ovms-server-v2: Sending server login: MP-C 0 XhtVVEbVmCGiPzPXVj9sP9 32BpNHY0zlKXNL2aLtLqSQ== ROADSTER_834
I (1377344) wifi: station: 40:4e:36:8a:44:c0 leave, AID = 1
I (1377344) wifi: n:1 0, o:1 0, ap:1 1, sta:1 0, prof:1
I (1377344) esp32wifi: AP station disconnected: id: 1, MAC: 40:4e:36:8a:44:c0
I (1377434) ovms-server-v2: Got server response: MP-S 0 /3r18R+pRv33vY+in6sJUn 7XOnvyGA4g0Ghg4CJhAgTw==
I (1377434) ovms-server-v2: Server token is /3r18R+pRv33vY+in6sJUn and digest is 7XOnvyGA4g0Ghg4CJhAgTw==
I (1377444) ovms-server-v2: Status: Server auth ok. Now priming crypto.
I (1377444) ovms-server-v2: Shared secret key is /3r18R+pRv33vY+in6sJUnXhtVVEbVmCGiPzPXVj9sP9 (44 bytes)
I (1377444) ovms-server-v2: Status: OVMS V2 login successful, and crypto channel established
I (1377454) ovms-server-v2: Incoming Msg: MP-0 Z2
I (1378444) ovms-server-v2: Send MP-0 S55,K,0,0,stopped,standard,0,0,0,0,0,0,0,21,0,0,0,0,0.00,0,0,0,0,-1,0,0,0,0,0,0,0,0.00,0.00,0
I (1378444) ovms-server-v2: Send MP-0 D0,0,5,0,0,0,0,0,0,1378,0,0,0,0,0.230769,0,0,0,0,0
I (1378444) ovms-server-v2: Send MP-0 F3.0.991-43-g0d28cb9/factory/main build (idf v3.1-dev-429-g7f6161cd) Mar 17 2018 14:20:07,,9,1,TR,gregnet3
I (1393284) simcom: State: Enter MuxStart state
I (1393284) gsm-mux: Start MUX
OVMS > metric set v.b.soc 33
Metric set
--------- Note: Started phone app here; new metric is properly displayed (i.e. transition from modem to wifi was handled properly! (Yea!)
I (1406724) ovms-server-v2: Incoming Msg: MP-0 Z3
I (1406724) ovms-server-v2: One or more peers have connected
I (1406734) ovms-server-v2: Incoming Msg: MP-0 Z4
I (1406734) ovms-server-v2: One or more peers have connected
I (1407444) ovms-server-v2: Send MP-0 S33,K,0,0,stopped,standard,0,0,0,0,0,0,0,21,0,0,0,0,0.00,0,0,0,0,-1,0,0,0,0,0,0,0,0.00,0.00,0
I (1407444) ovms-server-v2: Send MP-0 D0,0,5,0,0,0,0,0,0,1407,0,0,0,0,0.258242,0,0,0,0,0
I (1407444) ovms-server-v2: Send MP-0 L0,0,0,0,0,0,0,0,0,0,0
I (1407444) ovms-server-v2: Send MP-0 W0,0,0,0,0,0,0,0,0
I (1407444) ovms-server-v2: Send MP-0 F3.0.991-43-g0d28cb9/factory/main build (idf v3.1-dev-429-g7f6161cd) Mar 17 2018 14:20:07,,9,1,TR,gregnet3
OVMS > network
Interface#3: pp3 (ifup=1 linkup=0)
IPv4: 0.0.0.0/255.255.255.255 gateway 0.0.0.0
Interface#2: ap2 (ifup=1 linkup=1)
IPv4: 192.168.4.1/255.255.255.0 gateway 192.168.4.1
Interface#1: st1 (ifup=1 linkup=1)
IPv4: 192.168.43.49/255.255.255.0 gateway 192.168.43.1
Interface#0: lo0 (ifup=1 linkup=1)
IPv4: 127.0.0.1/255.0.0.0 gateway 127.0.0.1
DNS: 9.9.9.9 8.8.8.8
Default Interface: st1 (192.168.43.49/255.255.255.0 gateway 192.168.43.1)
OVMS > simcom
SIMCOM
Network Registration: RegisteredRoaming
State: MuxStart
Ticker: 39
User Data: 0
State Timeout Goto: PoweringOn (in 81 seconds)
Mux
Status: down
Open Channels: 0
Framing Errors: 310
Last RX frame: 0 sec(s) ago
RX frames: 0
TX frames: 2
PPP
Not Connected
Last Error: User Interrupt
GPS
Status: disabled
Time: disabled
NMEA: GPS/GLONASS Not Connected
OVMS > wifi
WiFi
Power: on
Mode: Access-Point + Client mode
STA SSID: gregnet3
IP: 192.168.43.49/255.255.255.0
GW: 192.168.43.1
AP SSID: ovms
IP: 192.168.43.49
AP Stations: 0
OVMS >
I (1464344) ovms-server-v2: Incoming Msg: MP-0 Z3
I (1468074) ovms-server-v2: Incoming Msg: MP-0 Z2
I (1468444) ovms-server-v2: Send MP-0 S33,K,0,0,stopped,standard,0,0,0,0,0,0,0,21,0,0,0,0,0.00,0,0,0,0,-1,0,0,0,0,0,0,0,0.00,0.00,0
I (1468444) ovms-server-v2: Send MP-0 D0,0,5,0,0,0,0,0,0,1468,0,0,0,0,0.263736,0,0,0,0,0
I (1512444) simcom: State timeout, transition to 2
I (1512444) simcom: State: Enter PoweringOn state
I (1512444) simcom: Power Cycle
I (1512464) simcom: State: Enter PoweredOn state
I (1522444) simcom: State timeout, transition to 2
I (1522444) simcom: State: Enter PoweringOn state
I (1522444) simcom: Power Cycle
I (1528254) simcom: State: Enter PoweredOn state
I (1529444) ovms-server-v2: Send MP-0 S33,K,0,0,stopped,standard,0,0,0,0,0,0,0,21,0,0,0,0,0.00,0,0,0,0,-1,0,0,0,0,0,0,0,0.00,0.00,0
I (1529444) ovms-server-v2: Send MP-0 D0,0,5,0,0,0,0,0,0,1529,0,0,0,0,0.258242,0,0,0,0,0
I (1529444) ovms-server-v2: Send MP-0 F3.0.991-43-g0d28cb9/factory/main build (idf v3.1-dev-429-g7f6161cd) Mar 17 2018 14:20:07,,9,1,TR,T-Mobile Hologram
I (1547464) simcom: State: Enter MuxStart state
I (1547464) gsm-mux: Start MUX
I (1547474) gsm-mux: Channel #0 is open
I (1547484) gsm-mux: Channel #1 is open
I (1547484) gsm-mux: Channel #2 is open
I (1547494) gsm-mux: Channel #3 is open
I (1547504) gsm-mux: Channel #4 is open
I (1548444) simcom: State: Enter NetWait state
I (1552444) simcom: State: Enter NetStart state
I (1553584) simcom: PPP Connection is ready to start
I (1554444) simcom: State: Enter NetMode state
I (1554444) gsm-ppp: Initialising...
I (1557684) gsm-ppp: StatusCallBack: None
I (1557694) gsm-ppp: status_cb: Connected
I (1557694) gsm-ppp: our_ipaddr = 10.170.146.142
I (1557694) gsm-ppp: his_ipaddr = 10.64.64.64
I (1557694) gsm-ppp: netmask = 255.255.255.255
I (1557694) gsm-ppp: our6_ipaddr = ::
I (1557694) netmanager: Set DNS#0 9.9.9.9
I (1557694) netmanager: Set DNS#1 8.8.8.8
I (1557694) netmanager: Interface priority is st1 (192.168.43.49/255.255.255.0 gateway 192.168.43.1)
I (1557694) time: Starting SNTP client
I (1590444) ovms-server-v2: Send MP-0 S33,K,0,0,stopped,standard,0,0,0,0,0,0,0,21,0,0,0,0,0.00,0,0,0,0,-1,0,0,0,0,0,0,0,0.00,0.00,0
I (1590444) ovms-server-v2: Send MP-0 D0,0,5,0,0,0,0,0,0,1590,0,0,0,0,0.263736,0,0,0,0,0
I (1590444) ovms-server-v2: Send MP-0 F3.0.991-43-g0d28cb9/factory/main build (idf v3.1-dev-429-g7f6161cd) Mar 17 2018 14:20:07,,8,1,TR,T-Mobile Hologram
I (1592344) ovms-server-v2: Incoming Msg: MP-0 Z1
I (1651444) ovms-server-v2: Send MP-0 S33,K,0,0,stopped,standard,0,0,0,0,0,0,0,21,0,0,0,0,0.00,0,0,0,0,-1,0,0,0,0,0,0,0,0.00,0.00,0
I (1651444) ovms-server-v2: Send MP-0 D0,0,5,0,0,0,0,0,0,1651,0,0,0,0,0.258242,0,0,0,0,0
OVMS > metric set v.b.soc 66
Metric set
---------- Note: Modem finally reconnects. Tested app; it's still working!
I (1701484) ovms-server-v2: Incoming Msg: MP-0 Z2
I (1701494) ovms-server-v2: One or more peers have connected
I (1702144) ovms-server-v2: Incoming Msg: MP-0 Z3
I (1702144) ovms-server-v2: One or more peers have connected
I (1702444) ovms-server-v2: Send MP-0 S66,K,0,0,stopped,standard,0,0,0,0,0,0,0,21,0,0,0,0,0.00,0,0,0,0,-1,0,0,0,0,0,0,0,0.00,0.00,0
I (1702444) ovms-server-v2: Send MP-0 D0,0,5,0,0,0,0,0,0,1702,0,0,0,0,0.263736,0,0,0,0,0
I (1702444) ovms-server-v2: Send MP-0 L0,0,0,0,0,0,0,0,0,0,0
I (1702444) ovms-server-v2: Send MP-0 W0,0,0,0,0,0,0,0,0
I (1702444) ovms-server-v2: Send MP-0 F3.0.991-43-g0d28cb9/factory/main build (idf v3.1-dev-429-g7f6161cd) Mar 17 2018 14:20:07,,8,1,TR,T-Mobile Hologram
OVMS >
---------- Note: still no joy on web browser when connected to ovms.
I (1858844) wifi: n:1 0, o:1 0, ap:1 1, sta:1 0, prof:1
I (1858844) wifi: station: 40:4e:36:8a:44:c0 join, AID=1, n, 20
I (1858844) esp32wifi: AP station connected: id: 1, MAC: 40:4e:36:8a:44:c0
I (1859884) ovms-server-v2: Incoming Msg: MP-0 Z2
I (1859884) ovms-server-v2: Incoming Msg: MP-0 Z1
I (1870464) wifi: station: 40:4e:36:8a:44:c0 leave, AID = 1
I (1870464) wifi: n:1 0, o:1 0, ap:1 1, sta:1 0, prof:1
I (1870464) esp32wifi: AP station disconnected: id: 1, MAC: 40:4e:36:8a:44:c0
I (1885444) ovms-server-v2: Send MP-0 S66,K,0,0,stopped,standard,0,0,0,0,0,0,0,21,0,0,0,0,0.00,0,0,0,0,-1,0,0,0,0,0,0,0,0.00,0.00,0
I (1885444) ovms-server-v2: Send MP-0 D0,0,5,0,0,0,0,0,0,1885,0,0,0,0,0.291209,0,0,0,0,0
I (1946444) ovms-server-v2: Send MP-0 S66,K,0,0,stopped,standard,0,0,0,0,0,0,0,21,0,0,0,0,0.00,0,0,0,0,-1,0,0,0,0,0,0,0,0.00,0.00,0
I (1946444) ovms-server-v2: Send MP-0 D0,0,5,0,0,0,0,0,0,1946,0,0,0,0,0.28022,0,0,0,0,0
OVMS >
OVMS > network
Interface#3: pp3 (ifup=1 linkup=1)
IPv4: 10.170.146.142/255.255.255.255 gateway 10.64.64.64
OVMS > wifi
WiFi
Power: on
STA SSID: gregnet3
GW: 192.168.43.1
AP SSID: ovms
IP: 192.168.43.49
AP Stations: 0
