[Ovmsdev] ota questions
Mon Mar 12 10:29:22 HKT 2018
> Working on the OTA web UI.
That will be very useful. Thanks.
> a) Flashing and changing the boot partition outputs some irritating overflow and "??" log messages:
> Can these safely be ignored? The flashed partitions seem to work correctly.
Yes, I too find these ugly. It is a ‘make monitor weirdism:
https://www.esp32.com/viewtopic.php?t=4199
No, no need to worry. Those are from the ``make monitor`` command. As soon as this sees a hex number scroll by that smells like an address in the ESP32 memory map, it tries to be helpful and converts it to a symbol. In some cases, this leads it to weird messages like this.
> b) How do you get back to the factory partition if something went so wrong you can't use the "ota" command?
Supposedly if the OTA partition doesn’t boot (or checksum mismatch, etc), the bootloader will boot factory.
The selection of current boot partition is in the otadata partition:
# OVMS 16MB flash ESP32 Partition Table
# Name, Type, SubType, Offset, Size
nvs, data, nvs, 0x9000, 0x4000
otadata, data, ota, 0xd000, 0x2000
phy_init, data, phy, 0xf000, 0x1000
factory, app, factory, 0x10000, 4M
ota_0, app, ota_0, , 4M
ota_1, app, ota_1, , 4M
store, data, fat, , 1M
I guess zapping that would reset to defaults (factory boot)? I think erase_region may do that:
esptool.py erase_region 0xd000 0x2000
But, haven’t tried it myself.
> c) ota flash http still gives me a DNS lookup error on any other host than api.openvehicles.com and fails to download from api.openvehicles.com, regardless of
> the type of network (wifi/modem).
I saw this a few months ago, but not recently.
Line 107 of ovms_net.cpp. It just does a getaddrinfo() on the host.
> Some questions:
> OVMS > ota flash vfs /sd/ovms3.done
> Current running partition is: ota_0
> Target partition is: ota_1
> Source image is 1480592 bytes in size
> Preparing flash partition...
> Flashing image partition...
> Setting boot partition...
> OTA flash was successful
> Flashed 1480592 bytes from /sd/ovms3.done
> Next boot will be from 'ota_1'
> I (1316956) esp_image: segment 0: paddr=0x00810020 vaddr=0x3f400020 size=0x5879c (362396) map
> I (1317156) esp_image: segment 1: paddr=0x008687c4 vaddr=0x3ffb0000 size=0x0382c ( 14380)
> I (1317156) esp_image: segment 2: paddr=0x0086bff8 vaddr=0x40080000 size=0x00400 ( 1024)
> 0x40080000: _WindowOverflow4 at /home/balzer/esp/esp-idf/components/freertos/./xtensa_vectors.S:1685
> I (1317166) esp_image: segment 3: paddr=0x0086c400 vaddr=0x40080400 size=0x03c10 ( 15376)
> I (1317176) esp_image: segment 4: paddr=0x00870018 vaddr=0x400d0018 size=0xfb154 (1028436) map
> 0x400d0018: _flash_cache_start at ??:?
> I (1317746) esp_image: segment 5: paddr=0x0096b174 vaddr=0x40084010 size=0x0e5b4 ( 58804)
> 0x40084010: spi_flash_mmap at /home/balzer/esp/esp-idf/components/spi_flash/./flash_mmap.c:293
> I (1317776) esp_image: segment 6: paddr=0x00979730 vaddr=0x400c0000 size=0x00034 ( 52)
> I (1317776) esp_image: segment 0: paddr=0x00810020 vaddr=0x3f400020 size=0x5879c (362396) map
> I (1317976) esp_image: segment 1: paddr=0x008687c4 vaddr=0x3ffb0000 size=0x0382c ( 14380)
> I (1317986) esp_image: segment 2: paddr=0x0086bff8 vaddr=0x40080000 size=0x00400 ( 1024)
> I (1317986) esp_image: segment 3: paddr=0x0086c400 vaddr=0x40080400 size=0x03c10 ( 15376)
> I (1317996) esp_image: segment 4: paddr=0x00870018 vaddr=0x400d0018 size=0xfb154 (1028436) map
> I (1318566) esp_image: segment 5: paddr=0x0096b174 vaddr=0x40084010 size=0x0e5b4 ( 58804)
> I (1318606) esp_image: segment 6: paddr=0x00979730 vaddr=0x400c0000 size=0x00034 ( 52)
> OVMS > ota boot ota_1
> Boot from ota_1 at 0x00810000 (size 0x00400000)
> I (301766) esp_image: segment 0: paddr=0x00810020 vaddr=0x3f400020 size=0x5879c (362396) map
> I (301966) esp_image: segment 1: paddr=0x008687c4 vaddr=0x3ffb0000 size=0x0382c ( 14380)
> I (301976) esp_image: segment 2: paddr=0x0086bff8 vaddr=0x40080000 size=0x00400 ( 1024)
> I (301976) esp_image: segment 3: paddr=0x0086c400 vaddr=0x40080400 size=0x03c10 ( 15376)
> I (301986) esp_image: segment 4: paddr=0x00870018 vaddr=0x400d0018 size=0xfb154 (1028436) map
> I (302556) esp_image: segment 5: paddr=0x0096b174 vaddr=0x40084010 size=0x0e5b4 ( 58804)
> I (302596) esp_image: segment 6: paddr=0x00979730 vaddr=0x400c0000 size=0x00034 ( 52)
> I would have expected "make flash" to reset the boot partition to "factory", as all flashes are only done there, but it doesn't.
> So if you're on another partition with a broken firmware, how do you recover? Is there a way to set the boot partition using esptool.py?
> OVMS > ota flash http www.google.com/ovms3.bin
> Current running partition is: factory
> Target partition is: ota_0
> Download firmware from www.google.com/ovms3.bin to ota_0
> Error: Request failed
> W (666891) net: DNS lookup on www.google.com failed err=200
> OVMS > ota flash http api.openvehicles.com/test.bin
> Download firmware from api.openvehicles.com/test.bin to ota_0
> […dead, needs reset]
> Is this a local problem of mine?
URL: <http://lists.teslaclub.hk/pipermail/ovmsdev/attachments/20180312/04429352/attachment-0001.html>
