[Ovmsdev] ota questions
Mon Mar 12 07:13:42 HKT 2018
Working on the OTA web UI.
Some questions:
a) Flashing and changing the boot partition outputs some irritating overflow and "??" log messages:
OVMS > ota flash vfs /sd/ovms3.done
Current running partition is: ota_0
Target partition is: ota_1
Source image is 1480592 bytes in size
Preparing flash partition...
Flashing image partition...
Setting boot partition...
OTA flash was successful
  Flashed 1480592 bytes from /sd/ovms3.done
  Next boot will be from 'ota_1'
I (1316956) esp_image: segment 0: paddr=0x00810020 vaddr=0x3f400020 size=0x5879c (362396) map
I (1317156) esp_image: segment 1: paddr=0x008687c4 vaddr=0x3ffb0000 size=0x0382c ( 14380)
I (1317156) esp_image: segment 2: paddr=0x0086bff8 vaddr=0x40080000 size=0x00400 (  1024)
0x40080000: _WindowOverflow4 at /home/balzer/esp/esp-idf/components/freertos/./xtensa_vectors.S:1685
I (1317166) esp_image: segment 3: paddr=0x0086c400 vaddr=0x40080400 size=0x03c10 ( 15376)
I (1317176) esp_image: segment 4: paddr=0x00870018 vaddr=0x400d0018 size=0xfb154 (1028436) map
0x400d0018: _flash_cache_start at ??:?
I (1317746) esp_image: segment 5: paddr=0x0096b174 vaddr=0x40084010 size=0x0e5b4 ( 58804)
0x40084010: spi_flash_mmap at /home/balzer/esp/esp-idf/components/spi_flash/./flash_mmap.c:293
I (1317776) esp_image: segment 6: paddr=0x00979730 vaddr=0x400c0000 size=0x00034 (    52)
I (1317776) esp_image: segment 0: paddr=0x00810020 vaddr=0x3f400020 size=0x5879c (362396) map
I (1317976) esp_image: segment 1: paddr=0x008687c4 vaddr=0x3ffb0000 size=0x0382c ( 14380)
I (1317986) esp_image: segment 2: paddr=0x0086bff8 vaddr=0x40080000 size=0x00400 (  1024)
I (1317986) esp_image: segment 3: paddr=0x0086c400 vaddr=0x40080400 size=0x03c10 ( 15376)
I (1317996) esp_image: segment 4: paddr=0x00870018 vaddr=0x400d0018 size=0xfb154 (1028436) map
I (1318566) esp_image: segment 5: paddr=0x0096b174 vaddr=0x40084010 size=0x0e5b4 ( 58804)
I (1318606) esp_image: segment 6: paddr=0x00979730 vaddr=0x400c0000 size=0x00034 (    52)
OVMS > ota boot ota_1
Boot from ota_1 at 0x00810000 (size 0x00400000)
I (301766) esp_image: segment 0: paddr=0x00810020 vaddr=0x3f400020 size=0x5879c (362396) map
I (301966) esp_image: segment 1: paddr=0x008687c4 vaddr=0x3ffb0000 size=0x0382c ( 14380)
I (301976) esp_image: segment 2: paddr=0x0086bff8 vaddr=0x40080000 size=0x00400 (  1024)
I (301976) esp_image: segment 3: paddr=0x0086c400 vaddr=0x40080400 size=0x03c10 ( 15376)
I (301986) esp_image: segment 4: paddr=0x00870018 vaddr=0x400d0018 size=0xfb154 (1028436) map
I (302556) esp_image: segment 5: paddr=0x0096b174 vaddr=0x40084010 size=0x0e5b4 ( 58804)
I (302596) esp_image: segment 6: paddr=0x00979730 vaddr=0x400c0000 size=0x00034 (    52)
Can these safely be ignored? The flashed partitions seem to work correctly.
b) How do you get back to the factory partition if something went so wrong you can't use the "ota" command?
I would have expected "make flash" to reset the boot partition to "factory", as all flashes are only done there, but it doesn't.
So if you're on another partition with a broken firmware, how do you recover? Is there a way to set the boot partition using esptool.py?
c) ota flash http still gives me a DNS lookup error on any other host than api.openvehicles.com and fails to download from api.openvehicles.com, regardless of
the type of network (wifi/modem).
OVMS > ota flash http www.google.com/ovms3.bin
Current running partition is: factory
Target partition is: ota_0
Download firmware from www.google.com/ovms3.bin to ota_0
Error: Request failed
W (666891) net: DNS lookup on www.google.com failed err=200
OVMS > ota flash http api.openvehicles.com/test.bin
Download firmware from api.openvehicles.com/test.bin to ota_0
[…dead, needs reset]
Is this a local problem of mine?
