[Ovmsdev] Auto start/init (was Re: Crash / reboot loop with log level Info)
Sat Mar 3 22:11:47 HKT 2018
Time component is fully implemented now. It support stale timeouts, re-elections, maintaining SNTP, etc.
> On 3 Mar 2018, at 8:42 PM, Michael Balzer <dexter at expeedo.de> wrote:
> Greg,
> I've just added ext12v and obd2ecu to the auto init system & web config.
> So except for the metric set command, you should now be able to start your module without a script.
> The autostart sequence is slightly different from yours, the obd2ecu init is done after the vehicle module init, as I see the vehicle module as the data provider for the obd2ecu module -- correct me if I'm wrong.
> Can you please verify the start sequence is working as expected?
> Am 25.02.2018 um 22:08 schrieb Greg D.:
>> Here's my system.start event file:
>> OVMS > vfs cat /store/events/system.start/mystartup
>> obdii ecu start can3
>> power ext12v on
>> wifi mode client gregnet3
>> # power simcom on
>> vehicle module TR
>> server v2 start
>> metric set v.b.soc 55
>> OVMS >
>> (Before you ask, the setting of the soc metric is so that I can see the server is actually talking to the module, when the module's on the bench.)
URL: <http://lists.teslaclub.hk/pipermail/ovmsdev/attachments/20180303/042d8cdf/attachment.html>
